03-28-2023
03:08
04:35
03-28-2023
03:08
04:35
6 month old Luxe won't charge or turn on.
I've tried 2 other Luxe chargers borrowed from my family and have now bought myself another new charger ... Luxe still won't charge or turn on. I've tried all the troublshooting suggestions. I'm not happy as I've had a few issues with charging from day 1.
03-28-2023 04:37 - edited 06-20-2023 08:56
Hi there, @mammasues. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out. I understand how you must be feeling.
To better assist you, please confirm that you've restarted your Luxe as described here How do I restart my Fitbit device?. Afterwards, please try charging your Luxe and see how it goes.
If the issue persists, please also confirm that you tried the troubleshooting steps provided here Why isn't my Fitbit device's battery charging?
03-28-2023 04:41
03-28-2023 04:41
04-01-2023 08:12
04-01-2023 08:12
Hi, @mammasues, allowing you have looked through the troubleshooting section in Why isn't my Fitbit device's battery charging? , in particular, the functioning of your chosen USB power source (you tell us you've had charging problems from day 1) I recommend you talk to "Customer Support" using the chat facility or phone for a prompt response. Before making the call make a note of the steps you've taken & the result along with details of when & where you bought your device, you may have the benefit of your "Warranty".
I hope this helps.
Cheers
Gr4ndp4 | UK
04-01-2023 10:02
04-01-2023 10:02
I'm also frustrated, there are more opened recent topics related to this serious issue(battery management/charging) after the last update (and sadly it seems ignored by Fitbit)
https://community.fitbit.com/t5/Luxe/Luxe-battery-is-draining-quickly-after-the-update/td-p/5343114
https://community.fitbit.com/t5/Luxe/Luxe-battery-is-draining-quickly/m-p/5363661#M11449
https://community.fitbit.com/t5/Luxe/Luxe-won-t-turn-on/m-p/5351403#M11237
04-01-2023 11:36
04-01-2023 11:36
Hi, @ICfl, welcome, you do not give details of your specific problem but if it relates to the battery drain you should contact "Customer Support" using the chat facility or phone for a prompt response. Before starting your call note the steps you've taken, and where & when you bought your device so the agent can quickly focus on their response.
Let us know how you get on.
Cheers
Gr4ndp4 | UK
04-03-2023 00:16
04-03-2023 00:16
@Gr4ndp4 I wrote the links, there are descriptions which is affecting me too. New topics are opened regarding this drain battery issue after the last update.
The last is here including my own description how to simulate the issue: https://community.fitbit.com/t5/Luxe/Luxe-battery-life/m-p/5363960#M11460
04-05-2023 05:05
04-05-2023 05:05
Hi, @ICfl, thanks for the update, did you contact "Customer Support" as suggested above? Moderators monitor these threads but do not provide direct support which is the "Customer Support" function.
Cheers
Gr4ndp4 | UK
04-05-2023 14:17
04-05-2023 14:17
