04-21-2022
15:54
06:49
04-21-2022
15:54
06:49
My Luxe keeps turning off, no matter what I do. If I try to reset it (plug in the charger, press button 3 times), it turns on after a few attempts, I can see it has 100% battery. I take it off the charger and after a few seconds it's off again (screen is black and unresponsive, not connected to the phone).
04-22-2022 06:50
04-22-2022 06:50
Hi there, @SakoDaemon. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out.
Please try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Hope that helps.
04-22-2022 06:50
04-22-2022 06:50
Hope that helps.
04-25-2022 14:39
04-25-2022 14:39
Thank you, that worked! I was worried that I'd have to send it for repairs, this was easy.
Best Answer04-26-2022 11:04 - edited 02-20-2024 03:17
@SakoDaemon Awesome! I'm glad to hear that the steps provided did the trick. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
04-28-2022 14:39
04-28-2022 14:39
Hello. Scratch that, it only worked for a few minutes, then stopped responding again and wouldn't turn on. I think there may actually be an issue with the battery... It's clearly turned off (no sensor light, doesn't sync with the phone), and only minutes ago it was at 100% battery.
Best Answer04-30-2022 03:35
04-30-2022 03:35
Yes my Luxe seems to work every other day. I have exactly the same problem that you have , it is so infuriating!
I will try the change the clock face suggestion, but can someone from Fitbit explain why we have to do this, it cost a lot of money and it doesn't work easily, please can someone reply to my issue..thanks
05-01-2022 11:10
05-01-2022 11:10
Brand new Fitbit luxe just got out of the box and I cannot get it to charge it will not even display the logo will not sync with my phone
