11-03-2022
06:06
15:47
11-03-2022
06:06
15:47
My fitbit luxe is working only when it is plugged to charger if we remove the charger the entire screen goes black and again if i pluh the charger then again it starts from charging 1% the same process is repeating
11-03-2022 15:53 - edited 03-08-2024 07:48
Hi there, @Hshss. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Luxe.
It seems like the battery is not charging properly, so I'd recommend trying the troubleshooting steps provided here Why isn't my Fitbit device's battery charging?
Hope that helps.
Hope that helps.
11-04-2022 06:56
11-04-2022 06:56
Hi, thankyou for the suggestions. I had done all those things but not working. Waiting for replacement.
11-05-2022 05:41 - edited 08-04-2023 04:07
@Hshss I appreciate you had followed the tips and recommendations provided above.
I've seen you contacted our Support Team after posting here and they've already assisted you. I'm glad to hear you're receiving a replacement.
