08-24-2021
14:12
06:30
08-24-2021
14:12
06:30
I got my luxe yesterday and wear it forcouple of hours bit the heart beat related data not recording in app. According to app "no measurements" in heart rate section of the app. Upgrade from charge 2 with lots of expectation but frustated to see it can not track and record basic task . hope fitbit will fix it soon.
08-25-2021 06:31 - edited 10-11-2024 06:02
Hi there, @PriyaDB. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your new Luxe. We‘re taking your comments and sentiments in regards to our products and services into consideration.
Since you both just got the Fitbit Luxe, give the heart rate a few days to settle down. It does some calculations, looking at heart rate throughout the day and while you are sleeping, so it might just not have enough data to give a reasonable value yet.
For more information, see the following help articles
Hope this helps.
Hope this helps.
08-22-2022 05:26
08-22-2022 05:26
I am a Luxe user. I had this problem and it was a ‘simple’ fix. I had inadvertently turned Heart Rate off in Settings. I think this is the first thing people should check if they aren’t getting a reading.
