04-01-2022
05:28
05:43
04-01-2022
05:28
05:43
Hi, I just got my luxe syncing perfectly on my huawai phone and then had to buy a new phone! The first week I had no issues and then suddenly i stopped getting texts/calls etc on my luxe again. I've tried all the trouble shooting tips but still not working. Any ideas please? Thank you
04-02-2022 04:24
04-02-2022 04:24
@SunsetRunner You may have either DND or sleep mode enable. When the do not disturb setting is on:
When sleep mode is on:
You can't turn on the do not disturb setting and sleep mode at the same time. For more information, see How do I navigate my Fitbit device?
If the above doesn't describe your issue, may I know if you receive any error message in the Fitbit app regarding the notifications not working? If so, what does it say? Also, may I know the model of your new mobile phone? Please make sure it meets the requirements listed here.
See you around.
Best Answer04-01-2022 05:44
04-01-2022 05:44
Hi there, @SunsetRunner. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Luxe. I understand where your concern is coming from.
It seems that your Luxe cannot connect properly to your new phone since you haven't yet forgotten the connection between your watch and the old phone's Bluetooth which would explain the connectivity issues you're running into. With that said, try the steps below:
Hope that helps.
Best Answer04-01-2022 10:40
04-01-2022 10:40
Hi, thank you for the detailed explanation. My Fitbit does connect fine though as it is also updated steps etc constantly. I therefore don't think it is a Bluetooth issue?
04-02-2022 04:24
04-02-2022 04:24
See you around.
Best Answer04-02-2022 19:49
04-02-2022 19:49
I am having the same issue, no issue connecting, my DND and Sleep modes are off and I haven't received notifications on my device for a couple of weeks now, I'm considering taking it back, but I'm not sure if will be the same with a new luxe.
Best Answer04-05-2022 00:27
04-05-2022 00:27
Thank you! My DND was on! No idea how that happened but now sorted 🙂
