07-09-2023
15:44
03:48
07-09-2023
15:44
03:48
This is strange, my Fitbit was working fine for the first couple of weeks and now I only receive reminders and notifications very occasionally and randomly. When I uninstall the app I receive all notifications. Any ideas?
07-10-2023 03:50
07-10-2023 03:50
Hi there, @kindnessmatters. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Luxe before reaching out.
I've seen you contacted our Support Team after posting here and they've already assisted you. Nevertheless, please note that your case was forwarded to our higher tier of support for further checking. Someone will be in contact with you soon as they have the resolution for your Luxe. Stay tuned to your inbox!
I hope we solve your issue soon.
Best Answer07-15-2023 06:48
07-15-2023 06:48
I am still having issues receiving reminders and notifications. I have not been contacted yet by support, is there anything I can do?
Best Answer07-15-2023 12:50
07-15-2023 12:50
I'm also having issues receiving notifications on my Luxe. I reached out to the Support Chatline, but we got disconnected and now that page isn't working anymore.
Best Answer07-15-2023 12:58
07-15-2023 12:58
I also tried the support chat line a couple of times and got disconnected. It’s getting very frustrating 😞
Best Answer07-15-2023 13:41
07-15-2023 13:41
Same, and I just bought this Luxe last week, it's so irritating that it's already having issues.
07-18-2023 04:38
07-18-2023 04:38
I’m having exactly the same issue with my Luxe, it’s been fine for few first weeks now stopped with notifications, so annoying, when do you think this will be solved?
Best Answer07-19-2023 05:10
07-19-2023 05:10
I’m not sure, but I finally got through to Support and it turns out mine seems to be defective, so they’re sending me a replacement. Did they run through some tests with you?
07-19-2023 05:16
07-19-2023 05:16
I have contacted support several times now and they have had me try multiple different things, nothing works. I will get one or two notifications and then it quits working again. Support said I would be contacted by email with a solution but I haven’t heard anything yet, that was 10 days ago. I’m happy they are sending you a replacement!
Best Answer07-19-2023 09:41
07-19-2023 09:41
Thanks! I’m sorry they’re dragging their feet with your case. If you’re still within the return period, maybe try returning it as it seems defective? Did you purchase directly from Fitbit or through an authorized retailer?
Best Answer07-19-2023 09:51
07-19-2023 09:51
I only just purchased my Fitbit online from the Fitbit website at the end of May so hopefully I can exchange it for another one. Because I’m in Canada I can’t request a return directly, I have to wait for support to email me 😞
I actually bought 2, one to give as a birthday gift for my daughter in September. I’m worried she will have issues as well, hopefully not!
07-19-2023 09:52
07-19-2023 09:52
I just got mine yesterday, everything works fine except for the notifications.
Best Answer07-19-2023 10:10
07-19-2023 10:10
That’s terrible 😞
Best Answer07-20-2023 16:25
07-20-2023 16:25
🙁 That's so weird you can't request a return, you're just across the border! Fingers crossed, although it seems to possibly be an ongoing software issue with all Luxes, potentially other Fitbit models as well? Hopefully, this gets cleared up by September so your daughter won't have to experience the frustration!
Best Answer07-20-2023 16:26
07-20-2023 16:26
🙁My replacement should be arriving this weekend, so I'll post an update on whether it has notification issues as well.
16:44
07:23
EstuardoFitbit
07-20-2023
16:44
07:23
EstuardoFitbit
Yes please update us when you get your new one, I’m curious if it will have the same issues or if it will be fine.
Moderator Edit: Formatting
07-20-2023 16:45
07-22-2023 21:16
07-22-2023 21:16
I just received the replacement and I still wasn’t receiving any notifications so I did more research and I finally got the notifications to work! I’m not sure what phone you have, but I have an iPhone and this is what I turned on:
Settings > Notifications > Messages > Under “Lock Screen Appearance”, the tab for “Show Previews” needs to be set to “Always (Default)” or “When Unlocked”. Once I did that, I had people text me and I immediately started receiving notifications. Hope this works for you!
Best Answer07-23-2023 06:03
07-23-2023 06:03
I’m happy you were able to get your notifications working! Unfortunately my phone is already on those settings. My issue is actually that I do receive a few messages after uninstalling my Fitbit, then after a short while I quit receiving them. Same thing for my Fitbit reminders to move. I don’t want to uninstall it every other day!
Best Answer07-23-2023 06:38
07-23-2023 06:38
