09-20-2021
19:27
04:39
09-20-2021
19:27
04:39
Several times now, I've been unable to reach the stopwatch on my luxe. Instead I am stuck on the timer. I use the stop watch a lot but not the timer. How do I stop this from happening? Is it possible to switch which feature is easy to get to?
Also can the timer be set for more than an hour?
Best Answer09-20-2021 20:21
09-20-2021 20:21
When you get to the timer, note the small up arrow at the bottom of the screen. Put your finger on that arrow and swipe up to switch to the stopwatch; from stopwatch, swipe the other way to get back to timer. It looks like the timer limit is one hour, but not sure about that.
09-21-2021 04:47
09-21-2021 04:47
Hi there, @Rapteur. Welcome to the Community Forums. Thanks for the details provided in your post. I understand where your concern is coming from.
To use the stopwatch on your Fitbit Luxe, please follow @JohnnyRow's directions or you can see How do I set a timer or use the stopwatch on my Fitbit device?
Hope that helps.
Best Answer09-21-2021 15:41
09-21-2021 15:41
Best Answer09-21-2021 16:09
09-21-2021 16:09
@Rapteur wrote:
... I attempt to swipe down and it literally does not work. It stays on the timer...
Maybe that was just a typo, but if not, you are wiping wrong way. From Timer, swipe up, not down, to get to stopwatch.
Best Answer09-21-2021 16:18
09-21-2021 16:18
Best Answer09-24-2021 07:58
09-24-2021 07:58
When I get to the timer, there is no up arrow in these instances. It is stuck on either the timer itself or it is stuck on selecting the time to count down for the timer. This is not always the case. I can often access the stopwatch, but when this occurs I can no longer access the stop watch until I rest the fitbit by using the charging cable... that feature in and of itself is somewhat ridiculous. I don't have the charging cable on me most of the time when I am seeking to reset the fitbit!
10-03-2021 15:59
10-03-2021 15:59
The Timer app includes a stopwatch. I have used it several times so I know where to find it and how to use it. The stopwatch is no longer on my Luxe. The Timer is there and functional, just no more stopwatch.
Fitbit app does not have a reinstall or update selection so there is nothing I see that can be done to reinstall the stopwatch.
Best Answer10-04-2021 01:37
10-04-2021 01:37
I can only reset this by restarting the Luxe. But it will happen again on the next day or even in the next hours…
Best Answer10-06-2021 10:24
10-06-2021 10:24
I went through the same thing. There was just timer not stopwatch. I don know why it happened. The only way to fix it was restating luxe. I think it's a bug.
