01-29-2023
08:07
21:00
EstuardoFitbit
01-29-2023
08:07
21:00
EstuardoFitbit
I currently have the Inspire HR which I’m really wanting to upgrade. I’ve tried 2 Versas, both of which do not track my heart rate or sleep through my tattoos (both wrists are tattooed). My current inspire works absolutely fine so I’m not sure why Fitbit can’t use the same technology in newer models.
I’d love to have the Luxe or a newer Inspire, so I’m wondering if anyone knows how likely it is these models will work through my tattoos as my current Fitbit does? Thanks for any advice in advance!
01-30-2023 01:49 - edited 01-30-2023 02:23
Hi @stackbit Unfortunately the only way to know if a device will work with tattoos is to try it. Do you know someone you could borrow one from?
Helen | Western Australia
01-30-2023 07:25
01-30-2023 07:25
I thought that would be the case! I don’t unfortunately, I’ll just have to buy and try!
01-30-2023 08:20
01-30-2023 08:20
Hi, @stackbit, I suggest you buy from a local retailer with a clear returns policy and open the packaging carefully so it can be returned as purchased in the best condition.
I hope this helps.
Cheers
Gr4ndp4 | UK
01-30-2023 11:53
01-30-2023 11:53
Yes I definitely agree. Thank you!
