Best AnswerFirst, welcome to Fitbit! I find the Flex really motivating to make my daily step goal.
I think your goal to lose 2-5 lbs per week is excessive. It is said to lose weight in a healthy manner, you should lose between 1-2 pounds per week, otherwise you are at risk in consuming too few calories which may actually cause weight to stick.
I know its annoying when you can't lose as much as you want but don't forget it didn't take a day to put on the extra pounds, its not going to take a day to lose the extra pounds.
Welcome to the fitbit community!
I recommend you go join MyFitnessPal.com as that site and this site work hand-in-hand. MFP does a great job for food entry. This site does a good job of activity/sleep entry. The two together is a dynamic duo of data for monitoring. 🙂
Hi! Welcome to fitbit. You are gonna love it! I get where you are coming from. Thirteen years ago I was pregnant with twins and gained, well, enough that the doctor said "um, this weight gain has got to slow down". Yeah, whatever, it didn't. They were 7 lb each; it's amazing what three Big Mac Meals in one sitting can accomplish. And I was WAY overweight. Over the course of a year, I counted EVERY morsel that went into my mouth. This was pre-smartphone, so I used a pen and paper. I lost about 1.5 pounds a week on average. Slow and steady really is the key. If you try for too much (and 2-5 lbs per week is too much), you most likely will fall off the bandwagon at some point. I couldn't manage 2 lbs per week; I got too hungry. Hang in there, count your calories, exercise (truly key for me), and it will work! BTW, it took me a year to lose all the Big Macs from my backside, so it's slow but worth it!
Best AnswerOne thing that can help is to record what you eat in the log. This has helped me to have accountability for my eating. For a woman of weight loss per week is recommend 1 to 2 pounds. If you can cut you caloric intake to 1200 but don't go much lower as you will go into starvation mode. I have also found that I need to make sure that I get a great mix of veggies and fruit with an increase in protein.
Hope this helps.
I am a cyclist so I will plug riding a bicycle for exercise. I started with 5 miles a day and now I do 12 to 20 miles when I ride. In the winter that is on the weekends in the summer I will ride 4 to 6 time a week with one ride of 30 plus miles. If you get into cycling be sure to hydrate:)
