01-14-2014 11:56
01-14-2014 11:56
01-14-2014 12:32
01-14-2014 12:32
Calorie burn is not an exact science. If you are trying to lose 1 lb per week that means your looking to burn about 500 calories per day more than you take in...
A couple of things.. its going to be hard to know for sure when you hit your goal because 1 lb could just be a glass of water being retained because you had a salty meal or you haven't had a good bowel movement or any other number of things.
The other is that your BMR may be lower than expected for any number of reasons. So you may be closer to 300 calories per day under even though Fitbit is estimating you ar close to 500. Body types, activities, and even the way we prepare food can play a part in our ability to lose weight.
Don't be discouraged, if you are staying 500 calories under the estimate, you are still going to lose that 1 lb even if it takes an extra day or two. Consider than if they are just 100 calories off, it will take 2 more days to lose that pound, because you will have only burned 2800 calories after 7 days as opposed to the 3500. 3500/400 = slightly less than 9 days.
01-14-2014 12:57
01-14-2014 12:57
02-02-2016 05:04
02-02-2016 05:04
Two things: first, there is a margin of error in both the calorie expenditure estimated by your Fitbit and in the calorie intake counted by you. Fitbit could overestimate your calories out by 250 calories and you could underestimate your intake by 250 calories, in which case a 500 calorie deficit turns into no deficit at all. Secondly, two weeks is a very short period: people tend to be too impatient and want to see results right away (hence the popularity of "xx days fixes"). The truth is: it takes time, and slow and steady is usually a better approach.
You may also want to add other methods to evaluate your progress, for instance by measuring your waistline, evaluating your body fat (in spite of its limitations, the Fitbit Aria scale is very convenient for that in my experience) etc.
Don’t be discouraged. If you know you are doing the right things, just keep doing it. If things are still stuck, you can make minor adjustments, like increasing your step count a little bit and/or decreasing your intake.
Dominique | Finland
