06-18-2016 20:30
06-18-2016 20:30
OK... So, it is 11pm and I exceeded my caloric intake by about 200 calories... I ate dinner about 1/2 hour ago... What can I do to burn th eextra baggage? (similar scenario here and there, once every 9 days or so)
06-19-2016 00:17
06-19-2016 06:33
06-19-2016 06:33
Have gratitude for only being over by 200 calories. You could have done much worse and tomorrow is a new day!
06-19-2016 07:00
06-19-2016 07:00
I go over my budget all the frk'n time! The good news is, that I'm still loosing weight. I set my goal for 2#s a week, which is rather ambitous but w/in the guidlines of healthy weight loss. I don't care if I do loose 2#s a week - so long as I loose and especially, not gain! I also try not to obsess about the scale and focus more on watching the inches melt. I get on the scale 1x a week & a messure 1x per month. I would say not to worry too much about it so long as you're seeing progress. Slow & steady is a more sure way of being able to keep off what you've loss.
06-19-2016 08:17
06-19-2016 08:17
@GershonSurge wrote:Go for a walk.
My reply was in the spirit of the thread "You know you are a Fitbit addict when..." For instance, if I'm away from home and my battery dies, I'll take a cab home.
06-19-2016 17:13
06-19-2016 17:13
LMAOOO... I can relate...
Best Answer06-19-2016 20:19
06-19-2016 20:19
@GershonSurge wrote:My reply was in the spirit of the thread "You know you are a Fitbit addict when..." For instance, if I'm away from home and my battery dies, I'll take a cab home.
I did drive out of my way on a business trip to a Target to purchase a spare charging cable. I was spending most of the day in meetings, and felt like I needed to track my walks I was taking at the end of the day. Turned out that where I was there were a number of people who walked circuits at lunch, so I just joined in and did some of my own.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
