Can I get my weight loss to adjust from when I STARTED my journey instead of when I got my fitbit?
So, I got my fit bit in February. I started my weight loss journey on December 18th. I logged the weight I was, but it only shows that I've lost like, 11 or 16 or something, since February. How can I get it to date back to Dec. 18th so I see the bigger number here? Hahaha 🙂 Thanks!
2 REPLIES 2
Hello @abeaumont16 and welcome to the Community.  I remember trying to help another user with the same question.  The settings for your weight loss journey are here: tap on your profile picture on your app > Activity & Wellness > Nutrition & Weight.  If I remember this right, you can't change the start date earlier than your join date (Feb).  I'm an iPhone user and I can edit the starting weight -- sometimes the iOS and Android apps behave differently.  Try editing you starting weight to your Dec 18 weight.  See if it works.  No guarantee.
This is your journey and you should feel good about it.
Laurie | Maryland
I can enter it... but it doesn't show weight lost since Dec 18. It's okay
though. . I know the real truth 🙂 lol
Thanks for taking time out of your day to try and help me
