05-03-2014 10:05
05-03-2014 10:05
05-05-2014 17:05
05-05-2014 17:05
Puggirl- I went from 187 to 137 with zero exercise. It's not a requirement.
When you say, "It's been three weeks and you didn't expect to plateau so soon", what are you considering a plateau? If you're like me, you lost 3 lbs. the first week, 2 lbs. the second and nothing since and you're annoyed and sure you're 'broken' and/or doing something wrong. With me, what I'm doing wrong is not being patient. Weight loss is never perfectly linear and when you don't have a lot to lose, I think it's even more jagged. Unless you're 4'8" and 80 years old, you will lose weight at 1000-1200 calories, though it might be slow. If it's been a month of 100% plan adherence and no loss, I would triple-check your calorie counting habits.
Good luck!
05-03-2014 10:18
05-03-2014 10:18
Hi. Your body is conserving weight because you are not consuming enough calories especially if you are exercising everyday. I would suggest looking into the Smarter Science of Slim by Jonathon Bailor or his most recent book The Calorie Myth
05-03-2014 10:25
05-03-2014 10:25
05-03-2014 10:30
05-03-2014 10:30
05-03-2014 11:36
05-03-2014 11:36
I'm just starting to lose weight as well. My doctor has put me on an anti-inflammatory diet and recommended me reading "Grain Brain" by Dr. Perlmutter. It's very interesting and looking forward to seeing how it will work for me.
05-03-2014 13:14
05-03-2014 13:14
05-03-2014 19:17
05-03-2014 19:17
I agree that your calorie level is very low. It is very difficult to lose weight if your activity level is low as well.
05-04-2014 00:06
05-04-2014 00:06
05-04-2014 19:07
05-04-2014 19:07
05-05-2014 12:41
05-05-2014 12:41
Yes Fibro will limit what you can do comfortably with exercise. I hope there is a modification that you can attempt like working out with a physical therapist or in a warm pool.
05-05-2014 13:05
05-05-2014 13:05
6,000 steps is more sedentary than trying to work to lose weight. I would recommend adding walk exercises in your spare time. There's plenty of space during work if there's nothing to do. A nearby stairwell, laps around the office cubical system, maybe a goal you can achieve like walking out of the office up to 1 mile away to a Coffee Shop.
During your off time if your family is looked after and you can open time for a 30 minute walk, it's only 30 minutes. Walk around your block. Or if you happen to go to the amusement park with the family (it is summer time afterall), you can spend lots of walk time there up to 10,000 steps or more in one day.
Like any Saturday, I could drive down to Fredericksburg, VA 3 hours away from home and enjoy a tour seeing all the attractions and get 20,000+ steps if I don't even bother sitting.
05-05-2014 15:42
05-05-2014 15:42
05-05-2014 17:05
05-05-2014 17:05
Tell me more about what you are eating? How frequent are you eating? Are you eating breakfast? How much water are you drinking? How many hours of sleep? Do you feel rested when you wake up? Give me a typical day from rising to bedtime okay?
05-05-2014 17:05
05-05-2014 17:05
Good luck!
05-05-2014 20:49
05-05-2014 20:49
With only 15 lbs to lose, I sure hope you picked a reasonable weight loss goal.
I'm guessing not though based on results.
1 lb weekly should be reasonable - unless your body has a lot of stresses it is dealing with.
Oh wait - it is indeed. Body dealing with disease is already under stress. Sleep good or bad? Guess which is additional stress.
You might lower your goal to 1/2 lb weekly to actually see success - since you are logging food so well.
How much daily on average does Fitbit say you burn?
How reasonable does the deficit appear now comparing what you burn to what you were attempting to eat?
05-05-2014 21:33
05-05-2014 21:33
@Heybales wrote:With only 15 lbs to lose, I sure hope you picked a reasonable weight loss goal.
Did MFP finally kick you out or what?
05-05-2014 21:54
05-05-2014 21:54
Not at all. Was actually asked to be a mod during their last expansion, but it was bad timing. Over 200 using the spreadsheet and losing weight that I know of specifically, and 21 that recovered their metabolism back to prior levels, but the whole EM2WL group is doing that too, among many others out there in the fitness sites advocating reasonable deficits for successful weight loss and maintenance. I'm hardly alone.
05-06-2014 18:18
05-06-2014 18:18
07-22-2014 22:03
07-22-2014 22:03
