02-28-2014 14:37
02-28-2014 14:37
02-28-2014 15:13
02-28-2014 15:13
If I am bad in the morning I am bad all day. I know we should try and spread calories, but I have to skimp on breakfast and lunch otherwise I eat double my calories it's like the more I eat the more I can't stop.
I also know if I am good all week I can ruin it with one trip to get a pizza. I almost hate going out with friends because I can't control myself.
02-28-2014 15:26
02-28-2014 15:26
02-28-2014 15:55
02-28-2014 15:55
I feel your pain, as I am the same way. I joined WW and lost 43 pounds 2 years ago. I have gained it all but 8 pounds back. COMPLETELY DISGUSTED with myself ! Why ? Why ? Why ? For me, I believe eating/weight loss is a total head-thing. I get "burn more than you take in", but I don't seem to view food simply as fuel for my body as much as I try.
Let me know if you have an epiphany in this area and I will do the same 🐵
02-28-2014 17:06
02-28-2014 17:06
02-28-2014 17:32
02-28-2014 17:32
Maybe overeaters anoymous can help. www.oa.org
02-28-2014 18:48
02-28-2014 18:48
I am struggling with the binging as well. I am horrible at night. It is crazy that I am allowing myself to do this over and over again!
02-28-2014 21:33
02-28-2014 21:33
EdinburghLass, this lack of control is my achilles heel too. I don't really understand why I let myself sabotage a few days/week of good work but I do. Things that have worked for me include physically removing myself from the kitchen area, not staying up late (the longer I'm out of bed the more time I have to binge and the weaker my will to resist) and most importantly, when I have had a good run of balancing eating and exercising I feel really great, mentally and physically and I try very hard to remind myself of that when I'm on the verge of eating badly. When weakness is about to strike I really stop and say to myself 'think how this will make you feel almost immediately after eating poorly' and also 'I've done so well so far, don't give in now'. And truth be told once I get on a really good jag these techniques do work and every little reduction I see on the scale I think 'yay me, you can do it'. And success breeds success.
03-01-2014 02:28
03-01-2014 02:28
03-01-2014 02:47
03-01-2014 02:47
When I feel that way because of all the calorie burn, I turn up the protein big time and drink tons of water! Try it! Also try air popped popcorn with all the fiber at night! I have problems getting very hungry depending on how much I burn - which is quite a bit lately - good luck! Vitamins too!!!
@EdinburghLass wrote:
I keep losing weight on fitbit and then ruining it all by binging and putting it all right back on again. I I could stop binging then I would be able to lose this weight. I'm so annoyed with myself right now. I lost 3lb this week, felt great, yet this evening I ate my own body weight in food. I seem to only be able to go about 2 weeks without a binge. I'm just stuck in this cycle. I can't remember a time when I've eaten normally, when I haven't binged. It's all I've every known and I want to stop so much. Does anyone else have this problem. I've just had enough. I know that it's really bad for me, it makes me feel awful, yet I can't stop doing it. I just don't know what to do anymore 😞
03-01-2014 02:48
03-01-2014 02:48
You can do this!!!! Don't give up!!!! - Your body is lacking nutrients!
03-01-2014 09:51
03-01-2014 09:51
Its a common problem......very, very common.
It might be worth discussing the issue with your Dr and getting a referral to a dietician. You say you lost 3lbs last a week, if you did this by cutting down or carbs or fat it might be you are sabottaging your efforts by cutting something your body really craves. A dietician should be able to work with you to find an eating plan that leaves you feeling satisfied and not so liable to resort to bingeing (by making sure you get enough of what your body wants).
03-01-2014 09:57
03-01-2014 09:57
Well this week all that I did was stick to the fitbit cals and steps...just eating a normal diet really, rather than binging. I'm not sure a dietician would help much to be honest, but thanks for the suggestion. I know quite a bit about food/cals/protein/carbs etc. I know what I should be eating! The problem is sticking to it! It's an emotional thing. I binge so I can feel numb and deal with the pressures of life...the same way others have a drink/cigarette etc. I need to find another way of dealing with things.
03-01-2014 12:58
03-01-2014 12:58
I know when I binge the most it's a long thought process. I debate and debate and end up still doing it. I know that it really helps to avoid triggers. One being I always ate two dinners one on the way home from work and one later that night. I try and avoid driving by fastfood or gas stations, I also try and make phone calls on the way home so my mind and my body are distracted from the triggers of the drive through. So I know when I am triggered to binge and I try to occupy myself with something else. I still fail sometimes at gatherings, but really I was binging everyday and gaining and gaining, now that I am loosing I don't try to do it fast all at once, and I am not saying no to any food at all, I am just keeping to my calorie guidelines and making sure I get as close as I can to my steps, if I don't make my steps I don't eat extra. I still have one day a week that always seems to go over but during the week I have been lower so it evens out. Like I said earlier I can't eat big in the morning because I can't stop. I am also not focused on only healthy and raw foods, I am making what I like and trying to reduce the calories or finding things that fill me that make meals heartier with out being calorie laden, i.e. I cut up zucchini and put it in all my pasta dishes and chili's and soup. Not many calories but it makes it more filling with out changing the taste. As I go I have incorporated more healthy foods, but my first battle was to get down the calories and step up the exercise. I got so defeated reading about how every food I liked was bad, I now avoid that and start adding veggies and fruits and making my meals better and more filling. It's a baby step process, and I have been sticking to it, because I am not changing it as much as I used to when I failed every time.
Recap: Busy yourself when you think you might binge
Don't say not to foods, but find healthy ingredients to make them more filling with out the calories.
03-01-2014 13:05
03-01-2014 13:05
03-01-2014 16:23
03-01-2014 16:23
You might be lucky and get a dietician that gives you an insight or advice that makes 'the difference'. As i get older I'm getting to be big on asking 'experts' for advice. I don't always take it, but sometimes someone with the right experience and knowledge can say something that turns on a mental light bulb.
03-01-2014 17:03
03-01-2014 17:03
I hesitate to get involved in this discussion. I have suffered for decades with this. It is a very serious problem that nearly killed me more than once. As a result I have turned around and become an activist in the field of eating disorders. I am the only person I know of that is speaking out in this manner and is 100% dedicated to what I am doing. I have met others but they seem to back out and are not committed. No, I am not at all overweight, and it is not becoming overweight that is the danger of which I am speaking. However, I have suffered with massive binges (quantity-wise) and I do not throw up. It is the binge eating itself that is the danger. I am a writer, have written a few books, and I have a master's degree but not in the field of medicine or anything related (thankfully).
No way is the textbook version of "binge eating disorder," that is, what medical students and psychologists and the like learning about at all correct. We sufferers are the ones that should know. The DSM, that is, the Diagnositics and Statistical Manual, now in its fifth version that now includes binge eating disorder, sadly, has got it all wrong. Medical science is doing us a disservice. The statement that binge eating is "highly treatable" is so untrue! Otherwise, this thread on this forum wouldn't even be in existence. Ever try to tell a doctor about this problem and feel like these folks just don't "get it"? That they can't help? Then you know what I mean. I can't post contact info but sure would like to know if others agree.
03-03-2014 09:56
03-03-2014 09:56
Oh @EdinburghLass -- I am right there with you!! Why do we sabotage ourselves?! I know what I need to do but just can't stop. So frustrating.
03-03-2014 13:48
03-03-2014 13:48
the recovery group part of OA has meetings online and loops that send mail to your inbox.
http://www.therecoverygroup.org/trg.html
Sometimes talking someone else down can help you as well.
I've dealt with this since I was a kid, I am in a phase of doing great right now.
03-03-2014 14:03
03-03-2014 14:03
