11-09-2017 10:43
11-09-2017 10:43
Can some one tell me how to change the measurement from lbs so I can record my weight loss
Best Answer11-09-2017 11:44
11-09-2017 11:44
Hi, @Littlechicke27, I am not 100% sure what you are asking, but if you would rather see your weight in kg or stones rather than lbs, on your app choose "account" (that's the icon that is meant to look a bit like an ID card -- a rectangle with a circle and some lines), and on the next screen scroll down to "Advanced settings" then choose "units".
If you are using the web based profile go here and scroll down to units. Be sure to save any changes.
I hope this helps!
11-09-2017 11:44
I hope this helps!
Best Answer11-09-2017 14:57
11-09-2017 14:57
Best Answer11-10-2017 09:33
11-10-2017 09:33
@Littlechicke27 I am happy Julia's suggestion worked and welcome to the forums! I am going mark her answer as your solution since all worked out..
Elena | Pennsylvania
