03-08-2017 19:18
03-08-2017 19:18
The main goal for having purchased a Fitbit (Charge 2) is the potential to lose body fat. I've been in and out of fitness and weight management over the past few years, so have some basic idea of calories in/out, BMR/TDEE etc. but the numbers Fitbit is suggesting to me are a little confusing. So I'm hoping someone more knowledgeable can help me understand.
My stats are:
Male
38 years old
98kg
Sedentary lifestyle
In setup, I said I wanted to follow the harder dieting path, with the 1000 calorie deficit. So Fitbit is now telling me to eat 1894 calories a day to meet that goal.
But every online calculator I use tells me that my TDEE is around 2500 calories. So shouldn't Fitbit be suggesting an intake of 1500 calories?
Obviously I'm missing something, so I'd be grateful to the Fitbit community for educating me on the finer points that I'm missing. ^_^
Best Answer03-08-2017 19:45
03-08-2017 19:45
Ideally you should avoid eating too much under your BMR. Unless you're very short 1500 calories is likely too low. Try this calculator, putting in your goal weight. Also, depending on how much you have to lose you may not want a large deficit.
http://www.fat2fittools.com/tools/bmr/
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
Best Answer03-08-2017 20:04
03-08-2017 20:04
Hey A_Lurker. Thanks for your reply.
As with the other calculators I've used, the link you provided calculated my BMR at 2093 calories. So that would put Fitbit's suggested calorie deficit below my BMR.
In any case, do you think I would lose weight at 2300 calories a day, if my TDEE is around 2500 a day? I appreciate the need for moderation and long term sustainability, but i wonder if i'd actually lose weight that way.
Best Answer03-08-2017 20:18
03-08-2017 20:18
I'd suggest that you set your deficit to the -750, which would bring you around your BMR for calories. Do this for 3 or 4 weeks and then evaluate how you're doing and adjust.
Best Answer03-08-2017 20:22
03-08-2017 20:22
OK, I'll give it a try.
Thanks.
