08-04-2014 08:50
08-04-2014 08:50
I am trying to sync my fitness pal food log to the fitbit. How do I go about doing this.
08-04-2014 09:12
08-04-2014 09:12
On MFP, go to "Apps" and then find Fitbit and click "Connect". That was all I had to do! 🙂
08-04-2014 09:31 - last edited on 08-04-2014 10:20 by RickyFitbit
Thanks so much, That worked. I appreciate it
Moderator Edit: Removed personal information
02-08-2017 12:52
02-08-2017 12:52
If you do this will it sync bothways or does it just export calorie burned from fitbit to MFP? (Or the other ways around) I´ve connected it but the logs i´ve entered in MFP doen´t appear in Fitbit
02-08-2017 13:14
02-08-2017 13:14
I did that so long ago. I can't remember anymore. You do know that fitbit has it's own log for food and it works pretty slick. Hope this helps.
02-11-2017 09:49
02-11-2017 09:49
I need help in reconnecting my fitbit with fitness pal, It quit working 3 weeks what the hell?!!
I reinstalled my fitness pal to sync up with fitbit charger 2 and nothing..
any ideas would be greatful, thank you..
06-23-2018 19:32
06-23-2018 19:32
I don’t have this option.
06-26-2018 12:07
