03-12-2018 00:52 - edited 03-13-2018 18:05
03-12-2018 3:40 PM
I am weighing myself everyday in the morning and I am going to log my results here. Feel free to join in.
Monday 61.0 kg 03/12/2018
Tuesday 60.3 kg 03/13/2018
Wednesday 60.3 kg 03/14/2018
Loss this week .7 kg
Loss to date .7 kg
"Every day is another chance to get STRONGER, to eat BETTER, to live HEALTHIER a"
03-12-2018 04:16
03-12-2018 04:16
@smppalos: nothing wrong in weighing daily (been doing it myself for the past five years), but I personally believe it’s better to reflect on weekly averages than daily individual values. This is because daily values are largely out of your control, whereas weekly averages tend to draw a better picture and show patterns. If your daily weigh-ins end up in your Fitbit account (whether automatically, if you have a compatible smartscale, or because you enter them manually), I highly recommend linking your Fitbit account to TrendWeight, a free web-based service that shows you (with the help of a clever moving average) where your weight is heading too. One of its advantages is it takes the focus off short-term daily fluctuations and puts it on longer-term trends. All the best in your endeavour!
Dominique | Finland
03-12-2018 17:37
03-12-2018 17:37
@Dominique Thanks! I'll try using TrendWeight. I've never heard of that before. I've just started monitoring my weight so I don't really know that weighing daily is not practical. Thanks for your advise!
03-12-2018 22:54
03-12-2018 22:54
I didn’t say weighing daily is not practical, only that reflecting on it is not optimal (IMO). Weighing daily is a good idea, especially if you start using TrendWeight: the more data points TrendWeight has, the more educated its guess will be (as to where your weight is heading) and the smoother its trendline will be. So my advice would be: weigh daily, write down the number / enter it in your Fitbit account (if you don’t have a smartscale that can automatically sync to it), forget about the number and move on to your other businesses for the day and analyze your weight on a weekly basis, with the help of TrendWeight. Note that you will need to "prime the pump" with TrendWeight, i.e. accumulate enough individual data points (preferably daily) for it to do its magic.
Dominique | Finland
