03-05-2019 14:20
03-05-2019 14:20
Can I start over, I think this has added up all my overages and taken away from the next day. Then I stopped tracking and its all out of whack. Also not sure when to charge, wont track sleep if I do at night of course.
Best Answer03-05-2019 15:17
03-05-2019 15:17
If your unit requires X hours to charge, then that’s X hours of missed tracking. No getting around that, so pick the time when tracking is least critical to you.
03-07-2019 10:54
03-07-2019 10:54
Agree with @Daveg22152. Just adding that there is no need to charge to 100% every time. I often will charge for 10 or 15 minutes while getting ready for bed, which is plenty of time to increase total charge by 25% or more, and then put it back on so it will record my sleep.
Every once and a while, just to keep the battery conditioned over its full range, let it get close to completely flat and then charge for a couple of hours to get to 100%. A good time to do might be while you are watching TV or a movie or some similar time period when you don't move much, but you also are not trying to track sleep.
Scott | Baltimore MD
Best Answer03-15-2019 10:16
03-15-2019 10:16
Thanks all for the advice on charging. What about the calorie counter? Based on my weightloss goals it showed I should have 1200 calories a day. Because I missed so many days I feel like the total went down to 795 calories because it was not showing any calories expended since I had it off for several days. Soooo how do I start over fresh, so it doesnt take into account the lack of movement, or is that not what is happening.?
