Hi all - interesting one for you...
I originally posted this and found it had corrected itself. But today, I entered my weight, 93.3 and it logged on the dashboard as 93.2. I deleted it and had to type in 93.33 to put the correct weight in.
I'm having issues when I use the dashboard online to log my weight. For instance, if I put in 94.5 kg's, it automatically adjusts it to 94.4 kg's. I have to enter my weight each day with a 2nd digit, IE: 94.53
Again if I put 94.52 it changes it to 94.4 and if I put 94.54 is changes it to 94.6! Very odd.
However when I do it via the app on the phone it adds it in properly.
Anyone else had this? Anyone got any answers? Suspect this is more a question aimed at FitBit themselves...
Best AnswerSame problem - the app either changes or deletes my manual logging - but your solution doesn't work for me. I log weight, save and it appears for a few seconds on the dashboard and then as I watch it is deleted...
Best AnswerUpdate: I logged out of the app on my iPhone. When I tried to log in again, I couldn't until I had gone as instructed into Setting - General - Date and Time and set timekeeping to automatic, following which I was able to log in and manually log my weight - and this time the loggings have not deleted themselves. So it looks as if it's something to do with clock-accuracy. Hope this helps someone!
