03-14-2015 17:19
03-14-2015 17:19
So I started my weight loss journey this time last year. I am 5'11 and started at 5'11 and am now at 169. I did this by using my fitness pal to count calories and started c25k and got hooked on running (getting ready to run my 3rd half marathon!). I have been stuck at the same weight range for MONTHS now. MONTHS!!!! My goal weight is 160 so I am soooo close. It's frustrating! So I just got the fitbit charge HR yesterday and started the food plan to count calories again. If I want to lose these last 9 pounds should I eat these extra calories from my exercise or no? For example I have ate 1,719 calories today and it's telling me I have 404 more calories to eat. I have burned 2,764 calories today (811 were from my work out today). Would love some advice! I want these last 9 pounds gone!
03-14-2015 20:30
03-14-2015 20:30
I don't eat the extra cals. especially later in the day when they will be stored. You run so have a lot of muscle weight. Are you sure at 5"11 that u need to be 141? Muscle weighs more than fat.
Logging your food makes sense as does drinking all the water since you are losing it by sweating. I'm not an expert but I think that we need to eat quality food.
I also have read that we use about 1260 cals. just to live a sedentary life if we are not very overweight. You sound at a healthy weight with a bmi of 20.9. Perhaps your body is trying to protect itself.
Heathy journey to you,
Barbara G
Best Answer03-14-2015 22:28
03-14-2015 22:28
You merely need to eat less than you burn in TOTAL daily by a reasonable amount to lose fat weight.
Do it by an unreasonable amount, you'll lose muscle mass too - that's not good short or long term success. Perhaps you have already experienced this if only doing cardio.
When you have less to lose, it's even easier to cause the stress and make that latter part happen.
So unwise choice trying for 2 lbs weekly, which obviously doesn't work for you now.
Better choice setting MFP to it sounds like 500 cal deficit.
Wiser choice though with only 8 lb to go would be a 250 cal deficit.
And reach your eating goal!
Are you willing to miss goal weight by 20% and say that's close enough? That's what you are doing with eating goal it sounds like.
Why not use the tool correctly?
Most tools used wrong at best just don't work to do what they could do. At worst they'll hurt you.
Guess which side of tool use you are likely on at this point. Sounds like you may not have used MFP correctly either, or you would have been eating more.
You've likely already stressed your body out, and Fitbit is estimating calories for a decently healthy body for which the stats are right - yours likely no longer is, so it's over-estimating calorie burn.
So 2 directions to go here. Keep eating less and less, and eventually you will start losing again, as the body can only slow down about 20% off healthy level. Fitbit estimate of daily burn will be useless at this point.
Adherance to such a low calorie diet may be terrible and you won't sustain it well, in which case you really won't lose that well. It'll be a stress on the body and exercise will not progress well, sickness can be more frequent, ect.
This is also usually the failure point for maintaining goal weight if you even reach it. Needing to eat about 20% less than would have been possible.
Other direction, let your body get healthy, let it burn what it could (though you've probably lost muscle mass and it's less than it could have burned), and then take a reasonable deficit. 250 cal, or 1/2 lb weekly.
During this time, exercise will probably transform your body more, unless only doing cardio, which doesn't do much transforming usually, especially not after a certain point.
Do the 2nd option by eating about 200 more daily for a week at a time, until you are finally eating what you burn.
Yes, take a diet break. What's a few weeks of purposely eating at potential maintenance compared to the months of nothing eating at suppressed maintenance, and future months of nothing if you keep doing the same thing that is causing no difference.
What's that definition of insanity ....... ?
Just speaking frankly and honestly about the potential you caused here, and how to get out of it.
Now, the only other thing this could be is if your food logging is so terrible and almost dishonest that you are wiping out an almost 1000 cal deficit daily.
But I'm assuming that's not the case.
Because whatever level you are eating at right now on average - is your maintenance. Suppressed maintenance. But like many others, you can get it back up to what Fitbit is suggesting, closer to potential maintenance.
03-15-2015 01:58
03-15-2015 01:58
I do eat extra the days with more exercice as I feel otherwise more hungry the day after. I am aiming for a 1 pound loss a week. Now counting calories is not easy or precise, but I take a daily deficit of 500 kcal (calculated) and see what happens with my weight over two weeks ( or a month) and then try to adjust to get my four pounds a month.
Best Answer03-15-2015 04:31
03-15-2015 04:31
No my goal weight is 160 not 141. That would be too low for me. I just weighed myself and today I am at 168. So I have 8 more pounds to lose. I'm doing the extreme food plan on here because I'm just sick of those extra pounds that I've been trying to get rid of for months that will not leave!
Best Answer03-15-2015 04:37
03-15-2015 04:37
I've actually been taking a "diet" break (I never called it a diet because I just did things in moderation) since Thanksgiving lol. I just started my fitness pal back on Thursday because I wasn't losing weight and I knew it wasn't because I wasn't being active because I'm super active but because I was eating like crap again and was probably eating too many calories. The only reason I didn't gain was because I was being active still. I strenght train too 4 days a week starting back the week of christmas because I want to tone up. I've been using the bodybuilding.com lean program and seeing some results there in my measurements just not in weight. I'm totally okay with eating the extra calories, I just wanted to make sure I understood it right before I ate them all. I'm super active so I burn a lot of calories so I guess I just have to eat a whole lot more, but in healthy calories (not donuts and french fries like I was). I am no way starving myself. Yesterday I had orange rolls for lunch and bacon and then a cheese burger for dinner but because of being so active I still wasn't at my calorie goal.
Best Answer03-15-2015 23:38
03-15-2015 23:38
Well, update us how your plan works in 1 month when it should be over then.
I'll be curious since you were asking for help, but seem to have it all figured out already.
