04-14-2017 16:31
04-14-2017 17:11 - edited 04-14-2017 17:12
You shouldn't need the Aria to get weight loss badges as far as I know. Where you log your weight shouldn't make a difference either.
I've gotten all of mine just through logging my weight from the beginning. Mine are in kgs, but it shouldn't make a difference, since the lbs badges are every 5 lbs.
I know there's been a bit of weirding out happening with the weight loss badges, but if you keep having an issue, you should contact customer support so they can look into it.
Best Answer04-14-2017 18:12
04-14-2017 18:12
I use the computer to log weights and don't use an Aria scale. It seems to me that sometimes you need to go away from the site and go back.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
Best Answer04-15-2017 06:36
