12-27-2016 10:10
12-27-2016 10:10
The question I want the answer to is this:
Does it matter if you enter body fat into the Fitbit app?
When you log weight, do you need to put in a body fat percentage or can you just leave it at zero? Can fit it still accurately record things like cardio fitness level without me putting in my body fat percentage?
Best Answer12-27-2016 19:57
12-27-2016 19:57
@Finn_Healy- You can just enter your weight. Body fat is optional.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
12-27-2016 23:44
12-27-2016 23:44
I assume you have a Charge 2, since it’s the only Fitbit that currently estimates your cardio fitness AFAIK. If so, cardio fitness score (whether expressed as a single number or as a range) does not use body fat, so entering body fat (if/when obtained with a third-party device) is purely optional (as @A_Lurker already said). It can be a good idea to enter it in your Fitbit Dashboard (together with your weight), so you can have a full history and see how it evolves over time.
Dominique | Finland
Best Answer12-28-2016 02:04
12-28-2016 02:04
@Dominique wrote:I assume you have a Charge 2, since it’s the only Fitbit that currently estimates your cardio fitness AFAIK. If so, cardio fitness score (whether expressed as a single number or as a range) does not use body fat, so entering body fat (if/when obtained with a third-party device) is purely optional (as @A_Lurker already said). It can be a good idea to enter it in your Fitbit Dashboard (together with your weight), so you can have a full history and see how it evolves over time.
Thanks
12-28-2016 02:04
@A_Lurker wrote:@Finn_Healy- You can just enter your weight. Body fat is optional.
Thanks
