07-06-2015 10:25
07-06-2015 10:25
I received my Fitbit Flex for Mother's Day and was ecstatic. Finally something to get me more motivated. I walk everyday, minimum is 5k per day. Yesterday I walked 21k and ate my calories made sure I was in "the Zone" and this morning up 1.5 lbs. I am just getting frustrated. I usually follow Weight Watchers and have for over 13 years, but I decided to use the Fitbit App and start counting my calories. I am using the 1,000 deficit since I need to lose 15-20 lbs. But I just keep yoyoing and I don't know what to do. How does this calorie thing supposed to work!! I thought I was doing it right. Very rare amount of processed foods, I drink 3000 ml of water everyday. Help!!!
Best Answer07-06-2015 13:10
07-06-2015 13:10
I know this sounds crazy but consider lowering your deficit to -750 or -500. If you have little to lose you should be trying to lose it slowly. You could be putting your body into "starvation mode" by not getting enough nutrients. If you are eating less than 1200 calories a day then seriously consider chaning your deficit.
I used to have a -1000 cal deficit and didn't lose much. Since changing to -750 cal deficit two weeks ago I have lost 4 lbs.
Best Answer07-06-2015 12:46
07-06-2015 12:46
Water retention after a big workout?
I think it was Heybale that was saying to weigh on the morning after a rest day, and it seems to be about right for me.
07-06-2015 12:56 - edited 07-06-2015 13:02
Tracy:
Six months ago I went on a disciplined exercise schedule along with reducing calorie consumption trying to avoid simple carbs (I still eat complex carbs), and fatty foods. In the first two months loosing weight seemed like an impossiblity and in some cases I'd yoyo down then back up and beyond. Then I spoke with both my doctor and trainer and they explained why this is a typical phenomena for those who begin a weight loss reduction plan. When you exercise you burn first your sugars, then starches (carbs) which are converted to sugars for fuel, and then when starches are used up the body draws down the fatty acids into sugars for fuel. An oversimplification for lay-speak, but it gives you a good picture. When you eventually burn down the fats from exercise you simultaneously build up your muscles and therefore exchange fat mass for muscle mass. The "weight" of both equal each other, roughly speaking, which is why you seem to not loose weight in the initial stages of weight reduction. You've got to be patient and as you continue to convert starch and fat into fuel you'll do so at a faster rate than you are building back muscle and therefore loose weight. I weighed 260 in January and am now at 233. Hang in there...it will work.
07-06-2015 13:10
07-06-2015 13:10
Best Answer07-07-2015 14:12
07-07-2015 14:12
Thanks,
I lowered my deficit back to -750 which initially when I started it that is where I had it. I changed it and then my weight was at a standstill. So I will see if that puts my body back into gear. ![]()
