12-25-2013 22:21
12-25-2013 22:21
what makes flex any better than an app like myfiness pal?
seems like myfitness does everything fitbit flex does ... cept track sleep?
12-25-2013 22:38
12-25-2013 22:38
yea, i'm beginning to think the same thing...trying out sleep feature tonight to see if it's worth it!
 Best Answer12-26-2013 09:51
12-26-2013 09:51
12-26-2013 12:08
12-26-2013 12:08
I agree with the previous poster. I have the Fitbit Force and also use MyFitnessPal. I have found MFP has a much more indepth food database and easier to add your own custom foods/recipes. While both FitBit and MFP estimate your daily burns based on averages, the FitBit should be a little more accurate. However, I still go one step further and use a Garmin Forerunner 210 with HRM during my workouts to get the most accurate calorie burn available (short of spending lots of time and money finding out my specific caloric burn rate). Hope this helps.
 Best Answer04-14-2019 22:47
04-14-2019 22:47
fitbit flex is better app than my fitness pal. first if you are using fitbit so you should use their own app because it is more compatible with these devices.
