Hi, i have been using the Fitbit Charge HR with Myfitness pal with good results. On monday i am starting weight watchers. from what i understand they have their own phone app, just wondering if anyone is using both and if they have had good results with the fitbit/ww app back and forth?
thanks.
You can link your Fitbit to WW. Its under account settings. Then Link Device
Here is an Article
It has been iffy. Sometimes it will sync others times not. The problen resdides with the WW site.
I dont use it as I found it to be very in accurate. Gave me way to many AP's. But a lot of people like it
This is the only thing that works with the WW app. The rest you need to log your Points at WW. The Point system does not work with Fitbit at all
Wendy | CA | Moto G6 Android
