02-11-2018 02:44
02-11-2018 02:44
Hi I’m a new fitbit user ☺️
When I look at how many calories I have burnt on my watch and in the Lifesum app, it dosen’t seem to match. Do anybody know why?
Best Answer02-19-2018 08:02
02-19-2018 08:02
Hi there! I work at Lifesum, I can give you a quick answer.
When Fitbit shows you your calories, it displays what you burn through activity as well as what you burn through just existing, living and breathing. What you burn just by existing is called your Basal Metabolic Rate (BMR). You can read more about it if you're interested:
https://en.wikipedia.org/wiki/Basal_metabolic_rate
Lifesum does not include your BMR when it shows your calories, it only shows calories burned from exercise. That's why the two numbers look different. Instead your BMR is shown as the amount of food you're allowed to eat if you don't do any exercise.
I hope that clears it up. Enjoy the two apps together!
– Lars
02-11-2018 23:17
02-11-2018 23:17
Welcome to the community, @vjeaninev!
First time I hear about the Lifesum app, but it appears it can be linked to your Fitbit tracker. I assume you have done so. If this is the case, calories burned should come from your Fitbit. If calories in Fitbit and Lifesum don’t match, maybe it’s a syncing issue?
Dominique | Finland
Best Answer02-11-2018 23:21
02-11-2018 23:21
Best Answer02-11-2018 23:27
02-11-2018 23:27
Hi
I have synced it to lifesum, but it still dont seem to match. I find it hard to believe that it might be a sync problem, considering that my watch is only 2 days old, but of cause I cant rule it out ☺️
Best Answer02-11-2018 23:59
02-11-2018 23:59
Are there any metrics other than calories (e.g. steps) that the Lifesum app takes from Fitbit?
Btw, a similar problem was reported last Summer by @JustasN.
Dominique | Finland
Best Answer02-12-2018 00:36
02-12-2018 00:36
I dont know to be honest. I have had my fitbit for 2 days, so I’m completly new to all of this ☺️
Best Answer02-12-2018 00:45
02-12-2018 00:45
I would suggest you focus on the Fitbit app for everything related to your activity (calories, steps, active minutes, heart rate etc.). The Fitbit app should display the same numbers as the tracker, once you have synced your tracker to your phone.
Dominique | Finland
02-19-2018 08:02
– Lars
12-06-2018 08:10
12-06-2018 08:10
What about step counts? I connected my Fitbit to Lifesum. The exercise calorie burns are being synced but the step count is coming from Apple Health not Fitbit. When I disconnect Apple Health, still no step data is imported from Fitbit.
12-08-2019 10:22
12-08-2019 10:22
Is it better to record your food eaten in Fitbit or Lifesum? Does food consumed/calories consumed in fitbit synch with Lifesum?
Best Answer01-10-2020 13:07
01-10-2020 13:07
Hi Lars,
I have a follow up question:
With this in mind (ie, the fitbit tracker is sending all activity calories through to lifesum), should my lifesum goat's activity levels be set to "low activity"? (Seeing as the fitbit accounts for all calories lost through any activity including steps etc?)
Thanks,
M
Best Answer01-16-2020 12:06
01-16-2020 12:06
Best Answer07-03-2020 08:22
07-03-2020 08:22
So, why is it not synchronising to my lifesum. How can I make that work, because on the app it Fitbit is compatible an I’ve turned that on but nothing is happening, which makes me to fill that in manually.
Best Answer07-14-2020 09:17
07-14-2020 09:17
Hi! I'm trying to connect my Lifesum to my fitbit, but every time I try to, it won't sync. Do you have any advice on how to sync it? Thanks in advance!
Best Answer04-13-2021 14:32
04-13-2021 14:32
Hi Lars!
I have a follow-up questions, if you are still here 🙂
I am not sure if the calorie adjustments Lifesum makes in the transfer from Fitbit works as intended.
I.e. today I tracked 30 min. jogging/running on my Fitbit. According to Fitbit I burnt 258 kcal. In Lifesum this running appears as "high intensity exercise" 30 min, but is reduced to only 95 kcal.
If I instead drop syncing with Fitbit, and register 30 min jogging directly in Lifesum, it appears as 260 kcal burnt.
How is this possible? Which number should I trust?
Best regards,
Mathilde
