08-17-2016 13:38
08-17-2016 13:38
Since I'm stuck with this new **ahem** dashboard how do I get it to show me the LBS I need to lose and the body fat I need to lose?
It's pretty useless showing no number and an arch over it. How do I get real info on the tile that I now have to scroll down to access?
08-17-2016 13:39
08-17-2016 13:39
I didn't say ahem....I used an acronym for piece of **ahem**.
08-17-2016 14:09
08-17-2016 14:09
I tried chatting with support. They ask how they can help then don't respond to questions.
I'm sure they're taking a beating today with users upset about the interface change.
Personally I voiced my opinion in the forums and it seems they and all others were roundly ignored.
Reap what you sow FitBit.
08-17-2016 15:21
08-17-2016 15:21
Is this a smart phone interface change? My dashboard looks the same as it did yesterday. I started the post to walk through how to set a goal, but then realized you were talking about changes. Sorry, wish I could help, but I can't.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
08-17-2016 16:32
08-17-2016 16:32
if it's not enough information on fitbit interface, i think you should try to google it,
i recommend here : https://www.reddit.com/r/loseit
and good luck
08-17-2016 16:50
08-17-2016 16:50
@Darkstar72 Try mousing over the tile. It should give you your weight and how much you have to lose. Clicking on the tile will also give you more information.
I hope that helps. Any more questions, just ask. We'll try to help.
08-17-2016 17:22
08-17-2016 17:22
@Darkstar72 I don't have a new tile on my dashboard but the old one shows everything if you click on more and you can work with settings as well. I don't like that when my weight goes down it also lowers my lean mass along with the fat. I got down to 102 and it still took away lean mass. Now I am working on putting on lean muscle and I am sure it is going to increase my BMI.
