08-08-2020 07:27
08-08-2020 07:27
😬My Goal Progress has now reset to today's date since I changed my weight loss goal. How do I change my "lbs lost since" date back to my original weight log date?? There used to be a way to add that date manually😳
08-08-2020 07:50
08-08-2020 07:50
Hello @AndPorter since you are not asking hardware support, I have moved your question to the managing weight .
Best Answer08-12-2020 06:21
08-12-2020 06:21
I don't know. I've been facing the same thing because I had been using smaller goals and then updating them. I've decided to put in my end goal and leave it (unless someone has a suggestion!) because I'd like to see the full progress here. I'll track the smaller goals somewhere else. Kind of a bummer to do it that way though.
11-25-2021 14:17
11-25-2021 14:17
I’m in the same boat. I wish someone knew/would answer. 🤷:female_sign:
