07-15-2014 15:17
07-15-2014 15:17
hi there
I just bought my fit bit about a week ago. Today i did a 20 min hitt work out. sweating and giving my all . went to check my burn and it said 79 calories ..... WHAT ?? no so what am i doing wrong or is my fitbit broken??
jen
Best Answer07-16-2014 01:59
07-16-2014 01:59
And sadly a HRM formula for calorie burn is only valid for steady-state aerobic where the HR is the same for 2-4 min.
And HIIT is totally opposite, if done correctly, anaerobic spikes and non-steady-state.
HRM formula will inflate the calorie burn. The more your HR jumps around with big gaps, the worse.
It actually doesn't burn that much as steady-state cardio during the workout time. If you had a HRM you might be surprised at how low the avgHR is for the whole session, despite the spikes.
Like lifting, which is what it's trying to mimic the benefits of for cardio-only non-lifting folks, the repair process takes more calories - and you don't get credit for that.
There are activities in the database that are similar.
Best Answer07-15-2014 19:32
07-15-2014 19:32
The fitbit only measures steps, it is not a heart rate monitor. It doesn't know you were doing a HIIT workout! You can "log" workouts that aren't walking/jogging/running, but these figures will only be an estimate based on the stats you enter. You have to wear a heart rate monitor (like a chest strap) to get a better idea of actual calorie burn.
07-16-2014 01:59
Best Answer07-16-2014 06:22
07-16-2014 06:22
Best Answer07-16-2014 08:05
07-16-2014 08:05
@jendawn wrote:
the lady at the store told me it would show me my calorie burn .. I told her I didnt want to spend 100$ on a stepper that I could pay 10$ for :(. so basically I wasted my money on something myfitnesspal does for free . wow . I guess I should habe looked more into it before buying.very disappointed now.
thank you for your responce though 🙂
Sent from Samsung Mobile
Well, it is better than a $10 pedometer, which merely sees impact and gives a step count. If it does calories, then it also assumes each step count is the exact same distance, and exact same calorie burn for pace that is seen.
Fitbit can tell the difference between steps, walking or running, full stride or shuffle step, ect. And that changes distance, that changes pace, that changes calorie burn.
But it is still step based activities.
So true for anything not step-based, the public databases on exercise are going to be about the same.
How many hours out of your 168 weekly hours are you exercising non-step based? 3% perhaps?
$10 pedometers also don't sync info out, nor account for rest of the day.
Curious if you mentioned to the lady what your workouts were, and what type of store was it?
Best Answer07-16-2014 08:18
07-16-2014 08:18
Best Answer07-16-2014 09:38
07-16-2014 09:38
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
07-16-2014 10:44
07-16-2014 10:44
@Heybales wrote:And sadly a HRM formula for calorie burn is only valid for steady-state aerobic where the HR is the same for 2-4 min.
I didn't know that! It's too bad we don't all come out of the womb with a little "calories burned" gauge. Life would be so much easier 🙂
Best Answer07-16-2014 21:09
07-16-2014 21:09
Sadly we do, the problem is it has about a 1 to 3 month delay for the guage to read correctly.
It's your belly and other areas with bodyfat adding up. By the time you notice, you could just see where you've been eating more, cut that out, and cut out about an equal amount more, to lose it again in 1-3 months.
But no one wants to wait that long, nor realize it was a small change that added up, only needed a small change to subtract it off.
