12-10-2019 20:09
12-10-2019 20:09
Best Answer12-10-2019 23:34
12-10-2019 23:34
In terms of energy expenditure (calories burned), your physical job definitely matters. In fact, you’re probably burning a lot more calories in a full day of work than during a 1-1.5 workout session at the gym, no matter how intense that session is.
In terms of fitness, it’s a bit different. Your job may involve very repetitive moves. Your body may also have adapted to your typical workload. It also depends on what one means by "fitness": it is cardiovascular fitness, muscularity etc.?
As to your concern, which is apparently lack of results with weight loss: if you rely solely on the numbers (calories burned as per your Fitbit and calories consumed as per your logging), you’re probably burning less calories than what your Fitbit says you are, and/or consuming more calories than you think you are. Make adjustments to your eating and activity level until you are in an actual deficit. The good news about being young and having a physical job is you can lose weight while still eating a decent amount of food.
Dominique | Finland
12-11-2019 02:47
12-11-2019 02:47
Of course people lose weight with a fitbit. Any activity that raises your heart rate into the fat burning or above zone increases your cardiovascular health and burns more calories than just being sedentary. If you operate at a caloric deficit and remain active you should lose weight.
Lifting weights in a gym may increase your muscle mass and being on a treadmill or a bike will help your cardio as well and burn more calories.
I lost 60 pounds merely by walking the 10,000 steps and riding a stationary bike 45 minutes a day.
I never went to a gym.
Keep your carbs low and avoid sugar to get faster results.
