04-13-2015
11:06
15:47
AlessFitbit
04-13-2015
11:06
15:47
AlessFitbit
I am the exact same weight as I was when I got my Flex 3 1/2 months ago!
How about you?
I'm hoping with Spring here and Summer around the corner, that my walking will increase.
Moderator edit: title
03-02-2017 22:46
03-02-2017 22:46
@medas2005 wrote:I would focus more on body fat percentage.
Yes, but how do you "focus on body fat", without losing weight? @FrogMystic said she incorporated resistance training in her program, which is indeed the right thing to do. I’ve found the only way I can reduce body fat is by losing weight.
Dominique | Finland
03-03-2017 05:35
03-03-2017 05:35
I agree with you that the primary way to lose body fat is to lose weight. I found it quite helpful to assess body fat each week (I used the scale at our community center) and multiply the percent fat times my weight to make sure that I was pushing my fat down, not just weight. I found that 2 or 3 hours per week of weight lifting in addition to my walking and cardio helped me achieve that.
03-03-2017 06:40
03-03-2017 06:40
@medas2005 The scale is just one metric for me, and I use it for overall trending information. Although I weigh every day, I don't focus on whether the number is high one day or low the next, but week to week whether the overall trend is downward. I also measure myself weekly at the neck, waist, and hips, and I gauge how my clothing is fitting. Interestingly, there is always a bump up on the scale after a heavy resistance day. If my research is correct, that's water and glycogen working to repair and refuel the depleted muscles. After a rest day, there's always a whoosh down.
To date I have lost over 10 inches in my waist, 8 inches in my hips, and over an inch in my neck. That tells me what I really want to know. The fat is going. At the moment, I can't be sure I'm not losing muscle, but I like to think I'm not losing much. My strength has increased. The body weight exercises I'm doing are intense, and I'm keeping my protein intake up. I'm not low carbing, because that doesn't work for me. It crashes my mood and makes my resistance training performance suffer. However, my carb intake is somewhat lower than recommended for an average diet. I use healthy fats for satiety and to make up that small deficit.
03-08-2017 13:57
03-08-2017 13:57
I got my FitBit on 12/20 and I've lost 1 pound. I walk 15 miles a week. I log another 6 miles a week running on the treadmill. And I weight-train 2 or 3 times a week. I record everything I eat, and I should have about 1,000 calorie a day deficit. Even if the calories burned is way off, I still should have lost something. It's very discouraging.
03-08-2017 14:19
03-08-2017 14:19
Walking 15 miles per week is great for your health. It is probably not enough to move the needle much on weight loss. I found that I started to lose weight when I exceeded 15K steps per day together with some gym works 2-3 times a week. At that point I began to lose a couple of pounds a week.
Good luck in your efforts, the road is not easy.
03-08-2017 14:33
03-08-2017 14:33
@medas2005 I wasn't very clear in what I posted. I'm getting about 16,000 steps a day on average. The 15 miles a week is just what I do as "added" exercise on my lunch hour (3 miles, 5 times a week). I'm not sure how many calories a days I was eating before I got the FitBit, but I'm only eating a1,200 calorie a day vegetarian diet now. It's very confounding. I'd like to lose 43 pound. Fortunately I have until Christmas time to do it 🙂
03-08-2017 14:39
03-08-2017 14:39
Well good, you are doing the right thing. In my experience, I worked almost two months before really started losing weight and then it changed pretty dramatically. I just kept working a bit harder and refining my food intake each week until eventually my body gave in and got smaller.
03-08-2017 14:39
03-08-2017 14:39
Your calories deficit might actually be too large. When you eat too little your body will hold on to the fat (weight) as a survival instinct. For a medium weight loss a 500 calories deficit is more typical. Try eating more for a few weeks and see if that helps losing weight.
Karolien | The Netherlands
03-08-2017 14:41
03-08-2017 14:41
03-09-2017 23:07
03-09-2017 23:07
@medas2005 wrote:I started to lose weight when I exceeded 15K steps per day
That was also the same for me, back in 2013. However, it was a case of out-exercising a poor diet. Now I know I could have achieved the same result with far less steps, by paying more attention to what and how much I’m eating. Not that I regret the time spent getting crazy step counts at one point: it didn’t hurt me and it certainly improved my fitness level.
Dominique | Finland
03-09-2017 23:57
03-09-2017 23:57
03-10-2017 08:33
03-10-2017 08:33
@Roboharrogate wrote:
losing weight 36lb since 20 Feb this year.
Today is March 10, so you’ve lot 36 lb in 19 days (an average of 1.9 lb per day)?! Several people in the community have lost 100 lb in a year, which I found very impressive and challenging. Another person recently reported a loss of 11.2 lb in 12 days, which left me speechless. But 36 lb in 19 days is something I just can’t understand. Yes, it is commonly admitted you need a deficit of 3500 calories for a weight loss of 1 lb, which means the deficit for 1.9 lb would need to be 6650. If eating 1600, total expenditure would need to be 8250. We’re entering Michael Phelps territory here.
Dominique | Finland
03-10-2017 16:11
03-10-2017 16:11
03-10-2017 16:14
03-10-2017 16:14
I tell you what, that's all that matters!!!!! I have 3 closets in my house full of clothes that "used to fit" but don't now. I flat out refuses to give them up! I've only had my fitbit since Feb 4th 2017, so I'm still trying to get myself into a routine or patter to walk or jog or just move more. I want to get into those clothes soooo bad!!
Lisa (aka, Igottalose30pounds)
03-10-2017 16:20
03-10-2017 16:20
Free weights is best, but you can do quite a bit with no weights or with a machine. I paid a trainer for just a couple of sessions and he put together a whole program of circuits for me to do. That was a year ago and I still do them now. I also do some things like squats when I am doing my long walk for the day. There are lots of pretty good programs on-line that you can find with a Google search.
I also switched over from a carb cereal breakfast to a protein shake breakfast which I just love and makes a big difference because protein is hard for the body to convert to fat.
03-10-2017 16:20
03-10-2017 16:20
kamiller,
Thank you so much for the advice and for sharing your weight loss experience!! You have truly inspired me to make a change!
03-10-2017 16:25
03-10-2017 16:25
Seg31,
Thank you very much for your inspiration. Unfortunately I am a die hard salt-aholic! I realize now that if I can cut that back and try to be active, maybe I'll see some results!
03-10-2017 16:47
03-10-2017 16:47
67 days with Fitbit, just over 1 million steps and weight loss so far of 15.1kg (33.3lbs).
Still a long way to go to reach a healthy weight, but the trend is encouraging.
As well as aiming for 10k steps/day (I've managed it 61/67 days), I've overhauled my diet.
I've gone from sedentary, gluttonous omnivore (meat, cake, chocolate, fried English breakfast etc., etc.) to Mediterranean diet, pescetarian, borderline veggie. And I love it.
I'm experimenting with veggie recipes. I've eaten more chickpeas/lentils/beans in the last couple of months than I had in the preceding 40 years!
Today, I made an amazing veggie pâté.
(http://www.amuse-your-bouche.com/walnut-roasted-garlic-chickpea-pate/)
My love of exercise and food has returned!
03-11-2017 00:54 - edited 03-11-2017 01:17
Hi
I feel like kinda stuck with walking (though that itself is going good as started basically at 0 steps and now average about 12500 per day). However, I find it difficult to jog/run still due to the weight. I did lose about 15 pounds in 7 months but more not happening even with the walk above. I started gym too where i have now started taking inclines on treadmill with decent enough speed as jog/run i still find it difficult. Any advise guys who might be into something like this or already crossed this hurdle?
03-11-2017 01:32
03-11-2017 01:32
@HemantP: there’s nothing wrong with walking, and with walking only. It’s safe for most people and can be sustained for long enough to burn a decent amount of calories. Although I have no problem running, I still prefer walking and this is what I’m doing most of the time. You may want to pay (more) attention to your diet, as it’s probably what is preventing further weight loss to happen. Since you’ve joined a gym, I would suggest you use it for resistance training (whether with free weights or machines), since you can walk outside the gym.
Dominique | Finland
