01-30-2014 10:53
01-30-2014 10:53
I have been eating close to the same diet. I started back on my treadmill and make sure to walk/run four miles a day. I have gaine 4 pounds. I really just do not understand why the scale is going up. I do walk on an incline of betwen 7-10 Is it possible this is causing inflammation ?? Confused
Best Answer01-30-2014 11:17
01-30-2014 11:17
Maybe it's water retention or muscle weight.
01-30-2014 11:17
01-30-2014 16:18
01-30-2014 16:18
Most likely some muscle weight plus water....... you have probably been drinking more fluids when you are working out than you did previously. Don't worry, your body will readjust in time. Just keep going!
Best Answer01-31-2014 02:22 - edited 01-31-2014 02:27
It's normal to gain weight when you begin exercising (or any time you increase intensity, duration or type of exercise). You retain more fluid. Just make sure you stay hydrated and watch your sodium and sugar intake.
I disagree that it is muscle weight. Muscle takes a long time to build especially when you're losing weight. You require an excess of calories to really build muscle plus strength training. Walking and running are cardio and will do very little to increase LBM... if anything, running a calorie deficit and just doing cardio is a recipe to lose LBM. If you're keeping track and being honest about how many calories you're taking in, it's most certainly fluid retention.
01-31-2014 02:34
01-31-2014 02:34
03-27-2014 14:51
03-27-2014 14:51
I completely agree Jabrat, I hate weighing. I don't want to see gains when I am working to lose. I dump the scale, calorie count, and step...step...step.
Best Answer01-27-2015 18:42
01-27-2015 18:42
Best Answer01-28-2015 02:40
01-28-2015 02:40
@zebrahamster wrote:
Yes, when you loose fat from diet and exercise , you also build muscle.
As @JenniLacey stated above, it's very unlikely you will build much muscle from exercising when on a diet, especially if it's cardio only and if you are a woman. Losing weight and gaining muscle takes time, you just cannot expect noticeable results after only a few days or weeks, no matter how healthy the diet is and how intense the exercising is. The original post is almost one-year old. Based on her profile, the original poster doesn't appear to wear her Fitbit everyday:
Maybe she has reached her goals and no longer needs it.
Dominique | Finland
Best Answer01-28-2015 03:28
01-28-2015 03:28
Muscle does not weight more than fat,1kilo of fat is same as 1kilo muscle.Muscle is more dense hence the more weight.
Best Answer01-28-2015 07:51
01-28-2015 07:51
Yes, when you loose fat from diet and exercise , you also build muscle. Muscle weighs more than fat. Don't give up this will change. You loose fat quicker than you gain muscle . Especially at first. Your body adjusts an you maintain a more steady weight loss.
Good luck P s. Drink lots of water😊
You will not build muscle that quickly. To gain a pound of TRUE muscle, it takes about 3 months.
What are you eating? Are you truly tracking your calories? Weight loss is fairly simple: calories in < calories out.
Also, just as a side note, not all calories are created equal.
01-28-2015 10:02
01-28-2015 10:02
Best Answer01-28-2015 11:58
01-28-2015 11:58
It takes more fat to equal 1 # than you realize. Just go to your local supermarket and ask them for 1 pound of pure fat an one pound of lean meat.
and if that pound of fat is from a pastured cow, ask them if you can keep it to cook with!
01-28-2015 15:30
01-28-2015 15:30
Best Answer01-28-2015 15:44
01-28-2015 15:44
