06-23-2014 03:13
06-23-2014 03:13
Hello!
I am French so sorry for my poor English level: i come here because i have a story and a little problem/question…
I hope this community will be more helpful than the French one 😉
First of all, a bit of “Storytelling”:
I have a FitBit One for more than 1 year. The main purpose was first only to discover my number of steps months after months (I like walks and statistics) and I had no “Weight Loss” goal…
Then, 5-6 months ago, quite stressfull moments got me to get bigger and bigger, then, few weeks ago I had a revelation: THIS MUST STOP!
So I began to really take care of my alimentation and I began to use the all Fitbit interface… And when I say all, it’s really all: daily weight, every aliments and calories eaten and weighted, every physical activity… And I also used the electronic coach included (the goal was to loose 5kg in 6 months: I wanted to discover my motivation before begin to be more ambitious).
And… it’s really working for the moment!! And faster than expected (I almost reached my goal 1 months and half after the beginning). But suddenly my old fashion scale broke up, and I decide to break my piggy-bank and invest in a FitBit Aria smart Scale (for me, the automatic filling of my every day weight to the dashboard by wifi was really a good way to keep de dynamic up !). This is how I discovered the % BODY FAT calculation.
And so, my problem: the more I lose weight, the more I gain body fat!!
And I don’t understand it (you can see the graphics below… In french, sorry!): I understand this figures that my efforts on my alimentation (I only took attention to the quantities first, I will check de kind of food eaten later) and on my physical activities (walk, swimming, bike… As never in my life) lead me to the good way on the weight, but in the very bad move on the body fat %!!
(In green, the body fat increasing. The blue sign is to point the date when I had the Aria scale.)
Does anyone understand and can explain me these figures? With all this sport, i can’t lose muscles right?
When I will have definitely reached my current goal, my real goal is to lose 5 more kilos till the end of the year… I would like to be sure that I go on the right way and that I don’t do any kind of wrong things…
Thanks for your help
05-11-2019 11:57
05-11-2019 11:57
05-11-2019 12:15
05-11-2019 12:15
05-13-2019 00:20 - edited 05-13-2019 00:21
@snoodlest wrote:
On Amazon the instructions for Aria 2 say “To get more accurate stats, set your scales to the right mode – Regular or Lean.” Could that be the issue? I only have original Aria.
I also have the original Aria, which also lets you choose between "regular" and "lean". It’s mentioned in the manual:
However, I can’t seem to find the place in the current Dashboard where you can change the setting. All I know is I’ve always been using "regular", ever since I bought my Aria six years ago.
Dominique | Finland
05-13-2019 01:41
05-13-2019 01:41
05-13-2019 06:00
05-13-2019 06:00
05-13-2019 09:12
05-13-2019 09:12
I poked around on the fitbit App on my iPhone and found it. Click on the upper right menu. Click on Aria. Click on People Using this Scale. Click on your initials. There you can switch on Lean Mode, and see if it makes a difference. Good luck!
05-13-2019 10:09
05-13-2019 10:09
Thank you, i only had the option to take it off lean so I did. I guess now I have it set to regular. I will see if this makes a difference once I weigh myself tomorrow morning uk time.
02-16-2025 07:33
02-16-2025 07:33
The issue I'm having is that how does the scale pick up on that. For instance, if I'm building muscle mass and losing fat, how does the scale just assume my fat percentage is increasing. That kind of technology can be misleading. I have the fitbit aria scale.
02-20-2025 05:07
02-20-2025 05:07
Thank you for the info
02-22-2025
02:18
05:38
FatimaFitbit
02-22-2025
02:18
05:38
FatimaFitbit
Weight loss and body fat management are all about balance—a proper diet, consistent exercise, and sustainable habits. Strength training, cardio, and a well-planned nutrition strategy can make a huge difference
03-04-2025 11:40
03-04-2025 11:40
Sadly the answer is contained in more detail in the prior posts to this old thread.
But short answer is by measuring resistance to a low electrical pulse, goes up one let down the other - unless your scale uses hand holds in addition.
Water is seen as lean body mass (many people call that muscle but that's inaccurate), so if you drank 16 oz's of water, and it was resting in the right spot to be seen - you just gained 1 lb of LBM. Which is obviously not true for muscle.
It's why body fat scale readings are ONLY valid at certain times, and even then over an extended period of time.
Just like a regular scale can't tell you what the 1 lb increase was from (did you just drink water), BF% even worse if used wrong.
Only valid times for both scales if you want a meaningful figure:
Morning after a rest day eating normal sodium levels.
Any other time will have mainly water weight fluctuations.
Also - it's much easier to lose a pound of fat then gain a pound of muscle. So if you lost 2 lbs after a couple weeks, but not much in the legs - it could be seen as increasing fat%.
@Marz8 wrote:The issue I'm having is that how does the scale pick up on that. For instance, if I'm building muscle mass and losing fat, how does the scale just assume my fat percentage is increasing. That kind of technology can be misleading. I have the fitbit aria scale.
08-18-2025 12:25 - edited 08-29-2025 01:49
Hi! First of all, congrats on your progress — losing weight and staying motivated is a huge achievement! It’s normal to see fluctuations in body fat percentage, especially when starting new routines or losing weight quickly. Sometimes the scale goes down faster than body composition changes, and small adjustments in strength training or activity can help balance it.I’ve been using something like the Sculpt Weight Loop to add simple resistance exercises at home. It’s great for toning muscles and can help support fat loss without needing a full gym setup. Maybe adding a few targeted workouts like that could help you see improvements in body composition alongside your weight loss.Keep up the amazing work — consistency is key, and it looks like you’re doing everything right!
