Calories burned is an average. Some people will burn more, some people will burn less. Weight loss is not always linear. If I under eat my weight loss sometimes slows down until I eat a little more. I'd pick something to do (eat to plan or under eat slightly), do this for 3-4 weeks and see how it goes. At that point adjust if needed.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
You need to determine your actual deficit (= the one that results in weight loss), as opposed to the calculated deficit displayed in Fitbit, which is an estimate. There’s a margin of error in both counting your intake and estimating your energy expenditure, for a number of reasons.
If you have been using your Fitbit and counting calories for long enough (at least 4-5 weeks), you should have a relatively good idea of your actual deficit. Maybe it’s just a question of substracting 300-400 calories from the calculated deficit you get with Fitbit.
PS: when posting, try to better describe in the subject line what your question really is about (most people are looking for "help").
Dominique | Finland
