01-05-2014 06:12
01-05-2014 06:12
I used the Fit Flex for the first time and did a High Intensity Workout and it said I only burned 30 calories however the Polar watch said I burnt 450?? How accurate is the Fit Flex?? ITs on my nondominant arm as told to do...HELP
Best Answer01-05-2014 06:35
01-05-2014 06:35
01-05-2014 07:17
01-05-2014 07:17
Your Polar is much more accurate. FitBit doesn't monitor your heartrate, which is an integral part to calorie burn. It also doesn't measure things that don't count as "steps", so push-ups, squats, etc. aren't taken into account.
01-05-2014 08:50 - edited 01-05-2014 08:52
The Fitbit Flex is a pedometer, a device that counts your steps. (It also can monitor your sleep but that is beside the issue here.) To calculate how many calories you have burned Fitbit uses the information it has about you at that current moment: age, weight and height to determine how many calories will be used by taking one step.
However, various activities such as running, jumping, dancing and all other activities will burn different amounts of calories because they will use more muscles, increase your heart rate, and so on. Fitbit itself however cannot monitor this. It just counts your steps. However, other things can monitor that if you want and some of those have intigrated their service with Fitbit.
Just as others have said to have abetter idea to know how many calories you have burned during anything else, but taking steps you would need to take a lot more into account such as heart rates and the likes. There are plenty of devices out there and even more applications that can help you monitor and share that information.
If you are going to use another service that can connect with your Fitbit account it will do the following: it will send their data to Fitbit. Fitbit than just puts that data as an activity in and use the calory value for that specific time span given by the service assuming it is more accurate than their projection (and it is more accurate). By doing things like that Fitbit will be far more accurate in projecting the amounts of calories you have burned during various activities Fitbit cannot monitor on its own.
Fitbit is not an all in one solution, but by intigrating Fitbit with other services to pick up where it cannot be the best, it will become a place to go to monitor most things you want.
I hope this has helped.
03-25-2014 18:20
03-25-2014 18:20
Do you prefer your polar because it has heart rate.? I am worried about trusting anything this tells me because my body efficiency is off....? Are there fit bits that have HR monitors?
@lisarn2 wrote:I used the Fit Flex for the first time and did a High Intensity Workout and it said I only burned 30 calories however the Polar watch said I burnt 450?? How accurate is the Fit Flex?? ITs on my nondominant arm as told to do...HELP
