02-04-2014 12:23
02-04-2014 12:23
02-04-2014 13:03
02-04-2014 13:03
You may want to check out some of the third-party sites that integrate with Fitbit. I personally use www.myfitnesspal.com (MFP) which can track poly/mono unsaturated fats (here is a screen shot of a report you can run through MFP):
I haven't used other sites like www.loseit.com but I assume they can do many of the same things. What I like about MFP is the cost (free), easy to use iOS app with barcode scanner, and integration with Fitbit to bring in all your food. Best of luck.
Best Answer02-04-2014 14:45
02-04-2014 14:45
Assuming you can get it to sync/integrate with Fitbit. I love the detailed nutrition analysis, hate that I have yet to get it to sync with the Fitbit.
