10-09-2017 12:28 - edited 10-09-2017 12:53
I have twice changed my target goal for losing weight (dropping from 235 to 220 and now to 200). I started at 265 and I want to see the total weight loss not just the weight loss from when I started a new goal. Is there a way to get the Fitbit to start counting pounds lost from a specific date and not simply from the date of the new goal?
10-09-2017 12:51
10-09-2017 12:51
10-09-2017 20:29
10-09-2017 20:29
There is no way to do it from a specific date. But you should have your goal set at your permanent Goal. Not mini goals. I think its important to see the total pounds lost. Not mini goals
Wendy | CA | Moto G6 Android
Best Answer10-09-2017 22:37
10-09-2017 22:37
What you could do to mitigate the problem is:
TrendWeight makes it very easy to have a look at your history and switch periods. If you select "All", you will easily see your total loss so far.
Dominique | Finland
Best Answer10-10-2017 08:07
10-10-2017 08:07
Honestly they weren't mini goals when I set them. When you are 265 pounds, just getting to 230 seemed unattainable at the time!
10-10-2017 09:24
10-10-2017 09:24
Yes, I probably used the wrong word: let’s say, intermediary goals.
Dominique | Finland
Best Answer10-11-2017 08:29
10-11-2017 08:29
@Chipc3 wrote:I have twice changed my target goal for losing weight (dropping from 235 to 220 and now to 200). I started at 265 and I want to see the total weight loss not just the weight loss from when I started a new goal. Is there a way to get the Fitbit to start counting pounds lost from a specific date and not simply from the date of the new goal?
@Chipc3 Try this from your computer.
1. Click "see more" on food tile (hover over tile until options appear at bottom, "see more" is on the right.)
2. Scroll right on the "Food Plan" until it changes to "Plan Summary."
3. Click "edit plan."
4. Change to starting date to the date you started losing and the starting weight to 265.
That should do it.
Scott | Baltimore MD
