08-27-2021
11:59
17:26
DavideFitbit
08-27-2021
11:59
17:26
DavideFitbit
How do I reduce in size and look fitted
Moderator edit: subject for clarity/format
Best AnswerHi @Madisomkate merged and moved your posts to the Manage Weight forum area. You need to take a look at what you're eating and what your activity level is. Which Fitbit do you use?
Best AnswerThanks so much
Best Answer@Madisomkate you're welcome. Which Fitbit do you have? If you use it to log your food intake and activities, you'll be better able to see what's going on. Some people use a scale, others see how well their clothes fit. So, what have you been doing?
Best AnswerUse scale and some outfit
Best Answer@Madisomkate You use a Fitbit? These forums are for those people using the devices. If that is your own picture used in your profile, I don't see as you are in any need to get into shape.
