07-03-2017 12:17
07-03-2017 12:17
I would like to see my daily macros as actual grams and not just percentages. Is this feasible on Fitbit? If so can someone tell me how?
07-03-2017 13:30 - edited 07-03-2017 13:31
It may just be a setting I changed at the beginning and don't remember, but I can see macros as both percentages and grams on my dashboard, but only as percentages in my app. Have you checked your dashboard? Maybe it's there. I hope this helps.
07-04-2017 13:43
07-04-2017 13:43
Great, thanks. Can see macros as grams & % on the dash board.👍🏽
10-18-2017 20:04
10-18-2017 20:04
Hello 🙂
I have a charge2. I can’t seem to find a dashboard that looks like yours, and I would like to see my grams of macros. Could you tell me what version your Fitbit is? Maybe I need to upgrade. Thank you! 🙂
10-19-2017 02:18
10-19-2017 02:18
That dashboard is in the browser. If you are on this forum there should be Dashboard in the top right corner (between Help and Store).
Karolien | The Netherlands
10-19-2017 05:13
10-19-2017 05:13
Thanks so much!!! Found it 🙂
04-01-2018 11:31
04-01-2018 11:31
Please note - carbs are not broken down into total vs. net! Carb counts will be significantly off.
01-14-2019 19:17
01-14-2019 19:17
Help! I have the Charge 3, i cannot find where this breakdown is as i want to see grams just for the protein at least.
02-28-2019 10:19
02-28-2019 10:19
I just tried this and it does not show on my dashboard. I have a Fitbit2. I tried from this online site as recommended and still not luck. Perhaps I am missing something?
02-28-2019 20:16 - edited 02-28-2019 20:25
@Moorknown wrote:I just tried this and it does not show on my dashboard. I have a Fitbit2. I tried from this online site as recommended and still not luck. Perhaps I am missing something?
Under the Dashboard, on the food tile, click the more info arrow - You will see the breakdown under the food plan. You may need to activate the food plan by entering start and goal weight and calorie deficit goals....
