06-14-2014 10:59
06-14-2014 10:59
What is the requimented daily salt intake?
Best Answer06-14-2014 14:42 - edited 06-14-2014 14:47
06-14-2014 15:18
06-14-2014 15:18
Previous post was just for fun 🙂
Typical daily salt intake recommendations are around 2,300 - 2,400 milligrams If you have a heart condition or have had a heart condition or surgery in the past, it can go down as low as 1,300-1,500 a day. Typically the less salt you eat the better, as it causes many people to retain water which makes you puffy and adds extra strees to your heart.
06-16-2014 08:39
06-16-2014 08:39
Thank you so much for you quick response. Really appreciate your help.
Best Answer06-17-2014 17:27
06-17-2014 17:27
@cp9102 Well it tickled my funny bone ![]()
Wendy | CA | Moto G6 Android
Best Answer06-25-2014 16:53
06-25-2014 16:53
Its also generally recommended that you reduce salt intake from a max of 2,400 to 1,400 once you get past age 50. At that point, telling kids to get off your lawn and reminicing about the 'good old days' is also common.
Best Answer06-27-2014 06:31
06-27-2014 06:31
Though if you are trying to lose body fat, you should minimize your salt intake (Sodium Intake). It's also not good for your blood pressure. Processed Foods have a very high amount of Sodium which retains in body water and fat percentage. You'll need enough water to reduce the percentage and as much strength and cardiovascular as possible daily to start the reduction.
