07-22-2018 12:46
07-22-2018 12:46
Do I use my tdee calories to be my bmr or do I just use the calories from my bmr?
Best Answer07-22-2018 10:16
07-22-2018 10:16
What is my bmr for someone who is a female, 4 ft 10 inches in height, 37 years old that has a 2000 calories per day? I have tried to do this on my own but I can't do it's too hard.
Best Answer07-22-2018 11:31
07-22-2018 11:31
If you want to estimate your BMR the same way Fitbit does it (implicitly) for you, you’re missing one parameter (in addition to gender, height and age): body weight. You can use this online calculator.
The calories you consume only affect your BMR very indirectly, via changes in your body weight. If you keep being in a caloric surplus, your weight will go up, and so will your BMR. Same in reverse if you keep being in a caloric deficit.
PS: please use more descriptive subject lines when starting new topics. For instance, the subject line for this topic could have been "how do I determine my BMR?". Relevant subject lines make it easier for other community members to see what the topic is about, and they also support future searches.
Dominique | Finland
07-22-2018 14:57
07-22-2018 14:57
@B3 wrote:Do I use my tdee calories to be my bmr or do I just use the calories from my bmr?
If you want to lose weight, your intake must be less than your energy expenditure (TDEE). It’s usually a good idea to eat at least the equivalent of your BMR, especially if you are physically active.
Dominique | Finland
07-22-2018 15:03
07-22-2018 15:03
@B3 wrote:What is my bmr for someone who is a female, 4 ft 10 inches in height, 37 years old that has a 2000 calories per day? I have tried to do this on my own but I can't do it's too hard.
There’s something wrong in your profile:
Your weight can’t be 30.6 lbs and your BMR can’t be 2000 calories either.
Dominique | Finland
07-22-2018 15:46
07-22-2018 15:46
What does that mean?
Best Answer07-22-2018 16:38
07-22-2018 16:38
I wonder if it's possible that her weight is 306 (not 30.6) pounds, in which case her BMR might actually calculate to be that high.
@B3 Do you weigh 306 pounds? Those BMR calculators are less accurate for people who are extremely obese, I think. If that is the case, I would recommend that you ask your doctor for some guidance.
If you are not extremely obese, then 2000 calories a day will certainly be too much for you. Knowing what you really weigh would help.
Best Answer07-23-2018 05:43
07-23-2018 05:43
Sorry my mistake, I meant to put 130.6 pounds and I am not sure what my real bmr is, I've tried to do it on my own but I can't do it, it's too hard.
Best Answer07-23-2018 06:28
07-23-2018 06:28
I think my bmr is1160 per day, would this be right?
Best Answer07-23-2018 06:58
07-23-2018 06:58
Yes, a 37-yo female, 4’10 tall, weighing 130.6 lbs would have a calculated (*) BMR of 1169 calories.
TDEE at the sedentary activity level (in Fitbit terms, less than 5k steps) would be 1469 calories. At the moderately active level (maybe something like 10-12k steps), TDEE would be 1812.
The additional activity would provide more flexibility for weight loss. For instance, you could be eating 1400 calories (above your BMR) and have a 400 calories deficit, which would allow you to lose at a rate of 0.8 lb per week.
If sedentary, you could be eating 1200 calories (barely above your BMR) and your deficit would be only about 250 calories (which translates in a rate of weight loss of 0.5 lb per week).
(*) using the same equation as Fitbit. Note that the equation is for the average person. In reality, people are distributed on a bell curve, and you could be on either side of the curve (slower or faster metabolism than average), depending on your genetics, your dieting history, medical conditions etc.
Dominique | Finland
