10-13-2015 01:38
10-13-2015 01:38
I've been diagnosed with a stress fracture in my 5th metatarsal.
I had previously been walking 10k - 20k steps per day, taking my calorie burn to around 2200 - 2500 per day. My calorie intake has been around 1500 cals per day. (I have 40lbs to lose)
Now, since I've been advised to stop weight-bearing activity for a while (6-8 weeks), my daily calorie burn has dropped to 1760 per day (av. 3k steps).
That is going to cause my weight loss to grind to a halt. I am planning to drop my calories to 1200 while I'm inactive but would only want to do that for a week or two.
Any ideas about how I can increase my daily calorie burn? I don't have access to a pool. I can't get to a gym but I do have free weights at home. I have started to use them but I understand lifting weights doesn't really burn many calories.
Help! Any suggestions would be gratefully received!
(I am a 51 yr-old female, 5'5", weigh 178lbs)
Best Answer10-13-2015 06:28
10-13-2015 06:28
Sorry, you couldn’t be more wrong....
I am not a runner, I dislike running longer than 25 min
Lifting weight give you this...
More effective weight loos
More muscle, more calorie burn
Quality sleep
A lots of energy
Your hart is a muscle, better hart health
Think of bone health
I lift heavy weight. I know what I am talking about. I Look at the mirror every day and
the most important I like the way my body looks….
10-16-2015 12:11
10-16-2015 12:11
10-16-2015 13:09
10-16-2015 13:09
@susie-q wrote:Thank you, Sam,
Is there any particular routine you would suggest I follow at home? I get really confused about all the different workouts - i.e, upper body one day, lower body the next - or, pull muscles one day, push muscles the next, then legs and when abs???
It's a minefield!
Can you please advise a simple routine that I can do at home. I have adjustable dumbbells, a resistance band and my bodyweight!
I used to work out years ago in a gym (in my early 30s) and I did enjoy lifting as heavy as possible. In those days I did a simple total body routine three times a week.
I can't get to a gym for another couple of months so I need something to build me up to that in the meantime.
Thank you for your help!
Compound exercise (those that involve more than one joint). Bench press, military press, rows, lat pullovers, squats (stress fractures may prevent this one), rows. For weight training the key is what they call volume. So for each exercise, do 3 sets with 5 repetition each so that the 5th is very difficult. Then drop the weight and do 3 more sets with 8 reps each, the 3 more sets with 10 reps each. The 10 should be quick movements, so the weight will be fairly light, especially since your muscles, if done right, will be really tired. Do all sets of one before moving onto the next.
Best Answer10-17-2015 19:38
10-17-2015 19:38
Fallow the divedragon advice.
At the beginning, do it every other day, Mon – Wend - Fri
10-13-2015 06:28
Quality sleep
A lots of energy
10-16-2015 00:38
10-16-2015 00:38
Thank you for your answer.
You are right, lifting weights has so many benefits and I will certainly be doing this. I was just asking about increasing the fitbit calorie burn to create more of a deficit without dropping too many calories, but I guess there's not a lot more I can do so I have to compromise here while I'm resting.
So, weights it is!
Thanks again!
Best Answer10-16-2015 05:41
10-16-2015 05:41
susie-q
Your body is one huge calorie burner. The more muscle you have, the greater burning is happening at any given time, yes at night too. Building muscle is not an easy task but if feels good to have it. Good luck.
Best Answer10-16-2015 06:00
10-16-2015 06:00
Thank you, Sam,
It's a minefield!
Best Answer10-16-2015 06:01
10-16-2015 06:01
You can get a couple of dumbbells or even lift a container of water if that's all you have. Sit in a comportable chair and do exercises from there. It all adds up, and while may not be as fun as walking, it will help get your heart pumping which is the most important part -- calorie burn is essentially tied to your heart rate... as long as you can get your heart rate up, you should burn more calories.
10-16-2015 12:11
10-16-2015 12:11
10-16-2015 13:09
10-16-2015 13:09
It's a minefield!
Best Answer10-17-2015 03:08
10-17-2015 03:08
Thank you for this. Would you suggest I go through them all on one day? 3 times a week? Or split them? Does it make any difference?
Best Answer10-17-2015 03:10
10-17-2015 03:10
Thank you.
You're right, I think I have been caught up in Fitbit steps! Now is a good opportunity to try other things and think about health and strength!
10-17-2015 19:38
Best Answer05-27-2017 06:46
05-27-2017 06:46
I almost submitted a post very similar to this today!
Best Answer05-10-2018 00:25
05-10-2018 00:25
I did receive them. They are just as beautiful as in the picture. And best of all.....they fit me! I ordered shoes with an easy, wide, 2" heel. Since it had been decades since I had walked in anything but a flat, I was a little concerned that I'd be twisting my ankle or some such. Nope. Didn't happen. I was careful, yes. But, the heel is wide enough yet stylish that I felt more dressed up than in any other shoes I'd had in many, many years and didn't embarrass myself by falling down. I did receive them. They are just as beautiful as in the picture. And best of all.....they fit me! I ordered shoes from orthofeet with an easy, wide, 2" heel.
