01-11-2017 18:33
01-11-2017 18:33
Hi! everyone. I am new to this board and to Fitbit. I received my fitbit after Christmas and was very excited. I only hit 10 000 steps twice. I have a wedding coming up and want to at least achieve 10 000 steps daily. I also would like to lose 5 pounds from now until then. I am 45yrs of age, weight 140 and 5 feet 4 inches. I know I am not overweight. I just want to lose a little and feel comfy in a bathing suit. We are going away on February 7th to Punta Cana. Any advice? Thank you 🙂
Best Answer01-11-2017 21:10
01-11-2017 21:10
Welcome!
Walking 10K a day will really not help you lose those 5#. Its more about what you eat. So cut back a little there some and Im sure it will fall off.
Exercise helps but its more about the food you consume.
Congrats on the wedding! Honeymoon sounds awesome! Enjoy!
Wendy | CA | Moto G6 Android
Best Answer01-12-2017 02:53
01-12-2017 02:53
Hi Laurience!
You've already know that even 10k steps it's not easy, but it's possible! Good luck!
Best Answer01-12-2017 06:57
01-12-2017 06:57
Thank you.. Love the pic..
Best Answer01-12-2017 06:58
01-12-2017 06:58
Very true.. yes, I will. It is my sis getting married. Not me, thank god.. lol
Best Answer01-12-2017 07:04
01-12-2017 07:04
@Laurience: Couple of things I would say, 1) avoid all kinds of processed food. 2) Drink lot of water. This would definitely help you to keep going and motivated.
Good luck
Bhuvana
Best Answer01-12-2017 18:05
01-12-2017 18:05
good luck!!!!!
Best Answer01-15-2017 09:42
01-15-2017 09:42
@Laurience; first of all, your weight loss "mini-goal" of 5 pounds in three weeks is perfectly doable. If you want ideas on how to do it, you may want to have a look at this thread on my rapid fat loss experiment. During this experiment (which started on Jan. 1st), I’m trying to lose 4 kg (8.8 lbs) in 4 weeks / 6 kg (13.2 lbs) in 8 weeks. I’m two weeks in and already down 2.5 kg (5.5 lbs) on the scale:
And I eat a lot of carbs, so it’s not the typical water loss trick typically experienced at the beginning of low-carb diets.
However, let me ask you this: let’s assume you achieve your mini-goal of 5 pounds before your sister’s wedding, then what? Are you going to store your Fitbit in a drawer and take it out the next time you have a need for another "quick fix"? For me, the value of Fitbit is as a motivator to make long-lasting changes in my habits that will result to permanent improvements in my overall fitness, health and well-being. So while it’s fine to have short-term goals, I believe you should also have a longer-term perspective.
Dominique | Finland
