07-08-2015 20:26
07-08-2015 20:26
Best Answer07-09-2015 03:13
07-09-2015 03:13
Don't eat them. You won't go into "starvation mode" unless your caloric deficit is very low for a very long time.
07-09-2015 03:13
07-09-2015 03:13
07-09-2015 07:36
07-09-2015 07:36
Best Answer07-09-2015 10:11
07-09-2015 10:11
I don't know - I would follow the guidelines, assuming you've got it set up well in the first place.
You didn't say how much weight you have to lose, but I have seen A LOT of people break plateus by upping their caloric intake. By the same token, I've seen people struggle because they've cut their calories too much, and they also lose quite a bit of muscle.
Why don't you try following what the plan says for a few weeks and see how it goes?
07-09-2015 10:54
07-09-2015 10:54
Lady,
Eat quality food veggies and lean protein. Don't eat extra cals if you are wanting to lose weight. 2000 -750 cals=1250 a day and that will help you lose 1.5 lbs a week. Not smart to eat much less for a long time.
Enjoy the journey. Measure as well since the fat is burned and the muscles get built so scale may not show the loss as you build muscle.
Happy health journey,
Barb
Best Answer07-09-2015 12:34
07-09-2015 12:34
"It depends"
What did you use to generate the numbers?
If its telling you to eat more, you probably need to eat more
