I want the dashboard to show my total weight loss
I adjusted my goals this week and I lost the total amount I've lost so far which is incredibly motivating for me. I found a topic with this fix...
On the phone app -
Go to the Account section (top right corner)
Scroll down to goals
Choose Nutrition & Body
Here you can manually adjust your target weight, start date and starting weight.
This will then show your total weight loss, rather than just since the last new target
I tried this but it won't allow me to change the date. Can someone help a girl out?
3 REPLIES 3
Hi JJ  Did you ever find out how to do this? I also have lost my starting information.  As you say it’s so motivating to see how far you’ve already come 😁
Hi Pam  So I lost my weight progress in September 21st when I adjusted my weight goal and then followed the instructions for the fix. as I stated above, I couldn't change the date. So I left the start date at the current date (Sept 21st) and entered in my starting weight. The next day I went in and adjusted the weight to my actual weight on Sept 21st. Whatever I did worked because now I can see my total weight lose but the start date is wrong, which doesn't bother me because I just want to see how much weight I've lost (34.8 lbs as of this morning!)
Worked for me - THANK YOU!
