03-15-2016 23:41
03-15-2016 23:41
Hi
I know it might sound an odd question but I've been using my fitbit for 2 years almost and have been in maintenance for over a year - I find that fitbit (Zip), with overlay from my HRM (polar) for specific workouts underestimates my calories (I probably have greater LBM than expected for my age tbh) by a couple of 100 a day
So, I thought if I knock 20 years off my age I might get 200 more calories or so? which would make it a little more accurate?
I've got it synched to fatsecret via fatmess (I used to use My Fitness Pal but could no longer cope with the ridiculousness and glitchiness)
Would that work or have I gone quite mad?
03-16-2016 09:08
03-16-2016 09:08
It probably would. By reducting your age in fitbit, you will more BMR credit. You can play around with BMR calculators to give you an idea how many years you'll need to knock off to find your "true" fitbit age.
Scott | Baltimore MD
03-17-2016 02:56
03-17-2016 02:56
Do you count your calories in? If so, do you find there is a mismatch between your total daily intake and your total daily expenditure (as reported by your Fitbit)? In other words, the scale shows you are eating at maintenance, but Fitbit claims you are in a 200 calories deficit?
If you are moderately active (as suggested by the 10k average step count of your profile), workouts performed on purpose probably only account for about 1 hour. That leaves 23 hours for the rest of the day. Even if your Fitbit under-reports calories for that 1 hour, it may still be right on a 24 hours basis. I personally wouldn’t bother adjusting my BMR by knocking years off my Fitbit age.
Dominique | Finland
03-17-2016 08:24
03-17-2016 08:24
03-17-2016 23:44 - edited 03-17-2016 23:45
It seems if I knock off 30 years and add 2 inches I should get another 190 calories each day
so welcome to my new world of being 5'10 and 18
03-18-2016 11:25
03-18-2016 11:25
@Rabbit= oh if that were truly possible..
Elena | Pennsylvania
