12-26-2014 12:14
12-26-2014 12:14
Hi everyone,
Just getting started with Fitbit and trying to set my goals. I have my goal weight set at 160 and my current weight at 185. On the dashboard it says Woohoo! Goal met. When I change my weight to 155, it says, 5 lbs to go. So the fitbit thinks I want to gain weight. How to I change it so it thinks I want to lose weight?
You'd think this would be a somewhat easy to find feature considering that's the whole point....
Best Answer12-26-2014 12:59
12-26-2014 12:59
Make sure you have your current weight entered. From the Dashboard click on the gear icon and select Settings. That should take you to a Personal Info page. Scroll down to Body info and enter 185 for your current weight.
