It would be great if the Force had it's own bar code scanner to log food.
It would be great if the force had it's own bar code scanner to log food faster.  I love using it with myfitness pal.  Even though integration with myfitness pal and fit bit may be possible the sync doesn't always work.  I have used the sync with Bodymedia and it would erase other things i inputted through bodymedia.
1 REPLY 1
I totally agree with you this should be a new feature. Someone has already been sugested go and give it a vote to encourage fitbit to make the change.
link: https://community.fitbit.com/t5/Product-Features/Bar-code-Scanning/idi-p/17429
Have a great day, keep fitbiting!
Eat Less, Move more and Keep Fitbiting!
Please remember to mark post as solved if you got the answers you needed. If you didn't find them here please tell us what did work. Also please if you find post and remarks helpful vote for them
