01-19-2021 06:13
01-19-2021 06:13
Can this be done as well as by weight? Thanks.
Best Answer01-20-2021 00:34
01-20-2021 00:34
It used to be possible but it was removed by Fitbit some years ago. There is a popular feature suggestion to bring it back and if you'd like to add your vote you can find it at:
https://community.fitbit.com/t5/Feature-Suggestions/Add-body-measurement-feature/idi-p/1653349
01-20-2021 00:34
Best Answer01-20-2021 01:26
01-20-2021 01:26
Best Answer01-20-2021 06:53
01-20-2021 06:53
Most of the weight logging trending apps, which is more powerful than the Fitbit logging in what it can show you, allow you to enter your own measurements and track them too.
Best Answer01-20-2021 06:56
01-20-2021 06:56
Thanks can you suggest one?
Best Answer01-20-2021 08:22
01-20-2021 08:22
Depends on your phone OS, but I use Libra on Android, Trendweight is popular on I think iOS and Android.
01-20-2021 08:40
01-20-2021 08:40
Cheers I'll take a look.
